I need some hinges for my 1934 Dodge coupe. Wondering if there's any other years besides the 1933 & 1934 Dodge and Plymouth that share the same hinges?
I guess a little clarification would be helpful. I'm looking for door hinges. I have several doors but it seems like every hinge I've seen on these cars has been hacked off on the body side of things. There's got to be some hinges out there somewhere that aren't torched or cut up.
I used a 34 Ford hinge to replace a broken one on my 34 Dodge pickup. Sorry I cant tell you what model it came from but it took very little modification to make it work.
There was a good reason why most of the body side of the door hinges were cut off. I'm building a 49 Dodge pickup. The truck cab had very little rust in it, and came out of southern MO. That cab had four 5/16" fine thread bolts that held each hinge onto the door post. The hinge slides into a slot in the door post, and the bolts pass through everything. Even with liberal penetrating oil over several months, out of the 16 bolts in both doors, only 6 total actually came out. The rest pretty much just broke the head off the bolts. The bolts passed through a sheet metal cover, then through slotted holes (for minor adjustment) in the body side door hinge, and threaded into a plate welded to the door post. Since the bolts broke off broke off even with the sheet metal cover, the door hinge still couldn't be pulled out of the slot it was in because the bolts still passed through the hinge holes. Even after drilling through the bolts, I still could not get the hinge to pull out of the slot it was in. I ended up cutting the door post apart to get the body side hinges out and making new pieces for the cab structure. I don't picture some guy in a junk yard that just sold a door to go through the effort I put forth. The first one they may have broke off all the bolts, then when they found out the door hinge still couldn't be removed, they would have just cut the body side of the door hinge off. After that 1st one, they probably just cut the hinges from that point on. Gene
