1933 Plymouth Roadster Show Rod, Big Block 440
Discussion in 'Cars For Sale' started by Hot Rod Dirty's, Mar 13, 2016.
  1. Hot Rod Dirty's
    Hot Rod Dirty's
    from KY
    City: Lexington
    State: Kentucky
    Price: $32k obo
    BEAUTIFUL... BEAUTIFUL... BEAUTIFUL!!!
    ........ 1933 Plymouth Roadster ........
    This Hot ROD just SitsRIGHT!
    and Has THE L@@K!
    We Feel this is Really a Work ofART
    that you can
    also Drive and Enjoy...
    ***Words Can't Describe howGreat this
    ...Car Drivesand HowFUN!
    Beautiful!
    TITLE IS FOR A 1933 Plymouth
    READY TO TRANSFER, NO PROBLEMS!
    BODY:
    1933 Plymouth Roadster Coupe
    Chopped
    Windshield
    Body has been Shaved and Bobbed
    Fabbed Deck Lid w/ Rounded Corners
    Suicide Doors w/ Bear Claw Door Latches
    Deck Lid has Hide-able Leather Pull Strap
    Fabbed Tail Pan w/ '58 Chevy Taillight Housings & '56 Lenses
    Kustom Steel Grille w/ working '58 Edsel Headlights/Bezels
    Smoothed Firewall w/ Moon Gauges
    Paint is Base White w/ Clear Coat Mixed with a hint of Red Pearl!
    Custom Antenna (can be changed very easily)
    THE ENGINE /DRIVETRAIN:
    1970 Steel Crank 440 Mopar Motor
    727 Automatic Transmission
    Drive train was from a Running/Driving
    ...36,000 mile Chrysler Imperial
    It was since tore down, inspected and Cleaned up
    New Gaskets were Installed
    Cal-Custom Valve Covers
    Chrome Headers
    Red Top Battery
    New Water Pump, Fuel Pump and Radiator
    Electric Fan keeps it running Cool!
    SUSPENSION/CHASSIS:
    Front Rails are Pinched 2x6 Rectangle, Rear is '33 Plymouth
    Front End is 4" Dropped Model A
    w/ Split '42-8 Wishbones and Chrome Pete and Jakes Spindles
    Chrome Pete and Jakes Bolt on Steering Arms
    Rear End is 8 3/4" Mopar Sure Grip (Posi) w/ 3:23 Gears
    Setup with Early Wishbones and Coil Springs w/ Panhard Bar
    New Firestone Wide White Wall Tires, (Big n' Littles)
    New Chrome Reverse Wheels w/ Spider Caps
    *New Pete and Jakes Super Stopper front Disc Brake Kit
    **Chrome Caliper Covers and Chrome Backing Plates!
    All New Brake Shoes, Wheels Cylinders and Rear Drum
    New Master Cylinder
    New Brake Lines, Transmission Lines, and Fuel Lines
    New Wiring
    INTERIOR:
    One of Kind and Comfortable
    Full Custom Interior w/ White Tuck n' Roll Throughout
    High Grade Boat Vinyl, Water is No Worry!
    Panels behind Rear Wheels, Front Frame Horns
    and Headlights are all removable!
    Brand New Lokar Shifter w/ Eelco Pistol Grip Shifter Handle
    Brand New Ignition Switch, High/Low Beam Switch and Fan Switch
    New Mooneyes Steering
    1951 Ford Gauge Cluster (would need rebuilt)
    New Glass
    New Gold Loop Carpet
    Trunk is Also Upholstered
    Splash Proof Fuel Cell
    Moon Tach not hooked up
    Very High End Looking and Feeling Interior!
    VERY COMFORTABLE !!!
    ..... Plenty of Leg Roomfor Bigger Guys!
    Call/Text: 606-776-2886
    Email: HotRodDirty@yahoo.com
    www.TraditionalHotRod.com
  2. Hot Rod Dirty's
    Hot Rod Dirty's
    from KY
  3. Hot Rod Dirty's
    Hot Rod Dirty's
    from KY
  4. Hot Rod Dirty's
    Hot Rod Dirty's
    from KY
  5. Hot Rod Dirty's
    Hot Rod Dirty's
    from KY
  6. Hot Rod Dirty's
    Hot Rod Dirty's
    from KY
  7. Hot Rod Dirty's
    Hot Rod Dirty's
    from KY
  8. Hot Rod Dirty's
    Hot Rod Dirty's
    from KY
  9. Hot Rod Dirty's
    Hot Rod Dirty's
    from KY
  10. Hot Rod Dirty's
    Hot Rod Dirty's
    from KY
  11. Hot Rod Dirty's
    Hot Rod Dirty's
    from KY
  12. Hot Rod Dirty's
    Hot Rod Dirty's
    from KY
  13. Hot Rod Dirty's
    Hot Rod Dirty's
    from KY
  14. Hot Rod Dirty's
    Hot Rod Dirty's
    from KY
  15. Hot Rod Dirty's
    Hot Rod Dirty's
    from KY
