Technical 1933 ford pickup
Discussion in 'Traditional Hot Rods' started by old chevy nut, Aug 18, 2017.
  1. old chevy nut
    old chevy nut
    from va
    hello im just starting a my 33 ford pickup build, my question is ill be using my full bed and rear fenders, what width rear end will fit nicely under it and sit in my fenders properly thanks for any help
  2. Harland grunder
    Harland grunder
    33 ford
    slim38 likes this.
  3. Petejoe
    Petejoe
    from Zoar, Ohio
    That depends on what rim and tire combo you plan to use. Offset makes a difference.
  4. old chevy nut
    old chevy nut
    from va
    a modern newer rear end
  5. MUNDSTER
    MUNDSTER
    I used a 8" ford. You'll need to measure everything and figure out what wheels you'll use
  6. woodsnwater
    woodsnwater
    from North Al.
    A ford 8" looks good (no back cover plate) and will handle close to 400HP. One out of a Granada is around 53" backing plate to backing plate and one out of a 67 cougar or mustang is around 58" I believe.
    LOU WELLS likes this.
  7. evintho
    evintho
  8. 32owner
    32owner
    my 34 has a ranchero rear end
  9. Before I suggest a modern rear end I would like to ask the "theme" of the truck? My 4 cylinder Chevy II powered AVATAR has a '32 rear end. If I was building your truck with a flathead, a Model B banger, or a 4 cylinder Chevy II I would definitely use a '33 rear end. With a powerful late model engine I would definitely go to a later rear end. What engine do you plan?
    Charlie Stephens
  10. sawbuck
    sawbuck
    from 06492 ct
    56 in to 58 in.wheel mounting surface
  11. Hotrodmyk
    Hotrodmyk
    1. Northwest HAMBers
    Using a Maverick 8" in my '34. It is 56 1/2" wide.
  12. sloppy jalopies
    sloppy jalopies
    we used to use mavericks... but if you find one, you should look close they have been sitting around for 30 years...
    bought one, the backing plates were rusted off... had a wider cougar, bent housing...
    I would consider new housing, axles and brakes... IMO.
  13. falconsprint63
    falconsprint63
    from Mayberry
  14. Schwanke Engines
    Schwanke Engines
  15. treb11
    treb11
    What wheel style / type / bolt pattern are you contemplating? Adn what other drivetrain mods are you planning? Rebuilding the stock rear with later juice brakes is an option.
  16. Schwanke Engines
    Schwanke Engines
    Spacers and adapters make this a non issue now.
    Sent from my XT1585 using The H.A.M.B. mobile app
