Project changed direction and I no longer need this frame setup. I did not build this chassis, but know the man that did and can get the buyer in touch with him if needed. Reproduction '32 rails (mfg unknown) Semi Boxed rails Concealed plumbing up front (brake and fuel lines) Vega Steering Mount Rails have all body mount holes, holes at boxing are threaded. Front fender holes are drilled and have threaded bungs. Home made channel X member Front crossmember was removed but new SoCal Model A crossmember is included with sale. Set up for rear coilovers (not included) but Traverse spring is possible 8" rear with 3:00 gears. Missing brake internals on one side of rear. Triangulated Three Link- Professionally Engineered and road proven (different chassis). Was Set up for SBC and T5. Motor mounts have been removed, but the trans mount remains. This is a super solid and rigid frame. It needs finishing up, but is a great start. *** Sale does NOT include wheels and tires or the wide 5 to 4.5" adapters (adapters could be for sale for extra $) *** I'm in South Austin, not too far from the LSRU.
