31 Ford modelA sport coupe turned into a 3 window coupe. Looks like they removed all the soft top parts and used a complete 3 window coupe roof from some unknown make to turn this into a 3 window. It does have a decent look to it, top is one piece and does mate up with the body fairly well. Top was heavily wood framed like GM cars. This is an old rod, probably 60's built.. Has 41-48 Ford suspension, 4 1/2" bolt pattern wheels, looks like an early dana rear end, possibly Willys Overland. Comes with headlights and grille shell, 3 speed stick trans and bellhousing for small block Chevy. Car was set up for these parts. Has cycle fenders up front, flat rear fenders welded on and filled into the body with filler, but the body stamping around the rear fender mounting area is not destroyed. Was channeled but not chopped. Needs every patch panel available. Rolls easily but rotted tires are flat. If you are not into fabrication and welding this is not for you. $2500 takes it. Trades considered. Yes its rough, but I have seen FAR worse saved on this site!
