"Wildwood" ...a1928 Ford Hot Rod Roadster Pickup **ask about our Financing! CALL or TEXT:606-776-2886 with Any Questions! BEAUTIFUL... BEAUTIFUL... BEAUTIFUL!!! ........1928 Hot Rod Pickup Truck....... Built in the Styling of a Traditional Hot Rod that would have been seen on the Dry Lakes in the 1950's! As Period Correct as Possible and Lots of Vintage Parts! This would make a great entry for events like the "Race of Gentlemen" Racing on the beach! Underslung Suspension allows the Hot Rod to Sit Nice and Low without an ugly Z in the frame! With Low Center of Gravity this Hot Rod Handles more like a Go-Cart! Underside is just as Nice/Clean as the Rest! Runs Cool! Tight Truck, No Rattles! Very Nice Handling Truck! This Hot ROD just SitsRIGHT! and Has THE L@@K! We Feel this is Really a Work ofART that you can also Drive and Enjoy... ***Words Can't Describe howGreat this ...Truck Drivesand HowFUN! Overdrive Trans allows it to be driven on the Highway! Beautiful! Reliable ! BODY: 1928 Ford Roadster Pickup Very Straight Body, Extremely Nice Original Model A Cowl w/ Fabricated Body Cut Down Bed and Tailgate from 60's Ford Truck No Rust, All Rust was Cut out and Replaced with Fresh Sheet Metal Custom mixed Shade of Green (comes with Jar of Paint) Original Real 1932 Ford Grill Shell Cut Down Late 20's Chevy Headlights w/ Halogen Conversion New 42'-48' Ford Blue Dot Taillights THE ENGINE /DRIVETRAIN: Fires First Crank Every Time! Keeps Nice Oil Pressure throughout drive 170 Cubic Inch Flat Head 6 Engine and Overdrive Trans from 1953 Studebaker Champion New Finned Aluminum Higher Compression Head from Cathcart Studebaker New Offenhauser Aluminum Dual Carb Intake from Egge Machine Custom Fabricated Linkage 2 Carter WE Single Barrel Cabs 1st Carb is N.O.S., 2nd Carb was Rebuilt w/ N.O.S. Kit Carb Scoops were made from Vintage Chris Craft Boat Deck Vents Dual Exhaust and w/ Handmade Wrapped Headers and Harley Davidson Fishtail Mufflers for very Unique and Interesting Exhaust Note Petronix Electronic Ignition Conversion w/ New Plugs, Wires, Cap, Rotor, Coil and Vacuum Advance Unit New Alternator w/ Aftermarket Pulley to fit Wider Vintage Style Belt Late Model 7.5 Rear End out of Chevy S10 w/ Adapters to fit the Ford Wheels 4.56 Gears installed work perfectly with the Overdrive Trans which is the original Studebaker Ratio New '65 Mustang 4 Row Aluminum Radiator w/ Electric Fan Keeps it Cool Spun Gas Tank in Bed SUSPENSION / CHASSIS: Underslung Suspension so that it can be driven extremely low with no worries about clearance / dragging. The Front and Rear Axles are Mounted above inverted Frame Front Half of Frame is Fully Boxed Model A Rear Half is 2"x 4" Box Tubing w/ 2"x 2" Box Tubing X Member Drivetrain is mounted so that nothing hangs below the frame Rails! Drilled Model A Front Axle with Model A Wishbones w/ Two Tone Paint 1948 Mercury Front Brakes w/ Custom Two Tone Paint 1940's Ford 16" Steel Wheels with New 1941 Ford Hubcaps Brand New Firestone Black Wall Tires and Tubes from Coker Firestone Deluxe Champions Bias Plys, 4.50/4.75-16 front, 7.00-16 rear Handmade and Drilled Friction Shocks Front and Rear Reversed Corvair Steering Box High End Small Dry Cell Battery Under Flip up Bed HANDLES Like None Other! INTERIOR: Vintage Seats from 1960's Renault Dauphine Interior and Bed Floor done with Hardwood Coated with Gloss Urethane Spar Varnish for Durable Finish then Trimmed w\ Aluminum Strips Bed Floor Hinges Up to Expose Storage Compartment! Vintage Glass Door-Knob Shifter Handle Genuine Vintage Ansen Swinging Pedal Assembly New 1961 Chevy Truck Clutch / Brake Master Cylinder Corvair Steering done in Two Tone New Heater Unit for Cruising even During Colder Weather! Wolf Whistle Vacuum Operated Whistle If your 6" Foot Tall This Roadster will Fit you Nicely, Very Roomy ** This Hot Rod is for sale for the right price!** but that doesn't mean the owner will give it away!, also don't be surprised if the auction is ended ...early if agood offeris made! Most of our Auctions only last a Few Days as car ~is also for sale locally Bid Healthy and Often my Friends! CALL or TEXT:606-776-2886 with Any Questions!
