For answers to any questions CALL Tom > at (918) 928-7540, If you don’t reach me, leave a > message…I will get back with you as soon as possible... > > Ford T Bucket,Registered as 1923 Ford Roadster, Lots of > Chrome Engine FORD > Displacement: 289 cubic inch 9.0-1 compression > Carburation: 2-4bbl 550 cfm Carter > Cam: Ford Hydralic Lifter > Radiator: Walker, Chrome Grill Shell (original steel Model > T) Valve Covers: Cobra Aluminum > Manifold: Edelbrock Dual 4 > Oil Pan: Cobra Aluminum > Ignition: Ford Dual Point HP. > Headers: Fabricated Sprint Car Style, Side Exhaust: 4inch > Chrome w/mufflers inside > Transmission > Make: Ford C-4 > Shifter: 65 Mustang > Driveshaft; Fabricated (Power Drive Wichita,Kansas) > Body > Body Style: 23 T Roadster, Manufacturer: Speedway Motors > Grill Shell: Chrome (original steel Model T ) > Paint: Gray Primer > Headlamps: Dietz > Outside Mirror: Billet > Chrome Plating on car done by Model Plating (Bell Garden > California) Interior > Dashboard: Brazilian Rose Wood > Wiring: Teflon Aircraft w/relays > Guages: VDO (Electric Speedo,Voltmeter,Fuel Level > ,Tachometer,Oil Pressure,Water Temp) > Steering Wheel: 4 Spoke 15 inch Sprint Car > Seats: Sprint Car Low Back Style > Upholstery: Red Marine Vinyl w/Cloth Inserts > Carpet: Wool > Chassis > Frame: 1.5inch x 3inch Rectangular Tubing (Performance > Engineering,Wichita,Kansas) Wheelbase: 96inch 46/54 Weight > Distribution Chassis Plumbing: Stainless Steel with AN > fittings Rear End: 56 Olds 3:34 ratio Chrome Plated > Rear Suspension: 4 Bar with Carrera Coilovers > Rear Brakes: Vented 12inch discs JFZ Calipers 2piston > Braided Stainless Hoses Proportioning Valve: > Front Brakes: 12inch Vented discs JFZ Calipers 1piston > Braided Stainless Hoses Front Suspension: 3inch Dropped > Tube Axle Spring behind axle Hair Pin Radius Rods > Complete Front End Chrome Plated, Steering Box: Corvair > w/bell crank for cross steering > Front Wheels: Genuine Halibrands (Santee Calif) 15x5 Real > Pin Drive Knock Offs Rear Wheels: Genuine Halibrands > (Santee Calif) 15x14 Real Pin Drive Knock Offs Custom Wing > Nuts and Pressure Plates Front and Rear Front Tire: BFG > Traction TA 195/65R-15 Rear Tire: Hoosier Pro Street > Radials 31x18.50-15 Gas Tank: Custom 10 Gallon > Chrome Plating done by Model Plating (Bell Garden > California) All Parts were baked to eliminate hydrogen > embritleness . > > Location: Tulsa, Oklahoma… fly in and drive this car > ANYWHERE it is in perfect condition, ready for any road > trip!
