A metal sculpture I just finished up. About 1/4 scale I suppose. Tires 10-11" tall and wheelbase about 2 feet.
Thanks guys. There have been several clone or tribute bikes built. I think Doc's has the original engine Red ran and it had some factory tweeks. He might have a few other original bits on his bike. The engine is all hand built from tubing, washers and flat bar. The Bell housing was a gear reduction from a small Briggs. Part of the carb was from a stomp start briggs and I added an old brass grease cup for a float bowl. Other parts are tricycle, sewing machine, baby carriage, bicycle. I had the ACE emblems done locally and had to trust them to distress them because they only print on white vinyl and I didn't want to sand into white. Since the original bike had a Merkel front, I had to go to the museum in Sturgis to get a bunch of pictures and see how it went together. In hindsight I used to fat of tubing but it is an accurate functioning fork, although there are no springs in it and it's set at a static hight. 116 fin pieces and every one had to have the welds ground down, I think about 50 hours into welding on fins.. Here's a few pics of the build.
Also I go to the dump for most of my tubing. Chairs, porch swings, cheesy throw away Mal-Wart shit. The pipe was a tapered table leg and the heat shield from the front of a Warm Morning heater, all from the city dump's metal pile.
Awesome! The more you show, the better it looks. If I remember you had a little daughter. Is she doing well?
She's doing good, in college and will turn 21 in March. She turned out to be a kind, beautiful girl and an awesome human being.
Oh, and the ignition, the original Sims mag is clowishly huge. Red used a Bendix I think but even it just wasn't going to look right to scale so I made a smaller one. The back I cut from a thick piece of bakelight. You can't really see the coils but they are wire I took from a coil wound onto sewing machine bobbins. The spark plugs are for some kind of model, NGK CM-6 and you can still find them. Wires are old cotton shellac wire I pirated from a 40 Ford parts truck. The brass lever on the mag is for advance/retard
wow, mine is turning 8 next week. It seems like yesterday I was holding her in the maternity ward. what a joy and a blessing they are.
