1848 chevy fleetmaster subframe install
Discussion in 'The Hokey Ass Message Board' started by hucks 48, Oct 18, 2011.
  1. hucks 48
    hucks 48
    looking for any info for a camaro or nova subframe install,what is the best one to go with, what year nova or camaro, found a 67 camaro subframe.any good shops in st.louis area?any help would be great
  2. chaddilac
    chaddilac
    My pop used a 72 camaro frontend and rearend, worked pretty good.
  3. Dangerous Dan
    Dangerous Dan
    from Graham Wa.
    Don't do it unless it's a rear steer. I just cut a 73 Camaro clip out of my 48 Chevy, to wide and tires rubbed fenders on turning, core support was literally destroyed due to interference with the steering gear. It was a hash job from the get go. I built a new sub frame out of 2 by 4 3/16 tube which slides inside the stock frame after cutting it off at the firewall. Then I installed a Mustang 2 universal weld in kit and it came out great.
  4. hucks 48
    hucks 48
    is a 67 camaro rear steer?
  5. 35mastr
    35mastr
    from Norcal
    67-69 is a rear steer. But its too wide for your car. Dont use it.
  6. enjenjo
    enjenjo
    from swanton oh
    Just step up for a Mustang. It looks better, gives more room around the engine, and is much lighter.
  7. need louvers ?
    need louvers ?
    Best post in long time!!! Greatest thing about a Camaro/Nova clipped pre '48 car? They are usually cheap 'cause they're not finished. Worst thing? Doing the above!
  8. ...don't tell me the early Camaro/Firebird/Nova & clones frontends won't work.
    I've done a bunch of em, no problems with any. I use only drum brake, rear steer subs, which are getting hard to find now.
    The front steer and disc brake subs are too wide.
