Technical 11” clutch problems
Discussion in 'Traditional Hot Rods' started by 29ron, Apr 11, 2022.
  1. 29ron
    29ron
    I am running a 59ab flatty with a 39 3 speed top loader. The flywheel is drilled for a 11” clutch. I have a new 11” pressure plate and clutch disk. The problem is I can push the clutch pedal in about half way and the motor will disengage from the gear box but if I push the clutch pedal all the way in the pressure plate fingers hit the clutch disk and engage the clutch disk to the motor. And thoughts or advice?
  2. rusty valley
    rusty valley
    And you have the proper 3/4 to 1 inch free play on the pedal before the throwout bearing makes contact? You can see the contact thru the inspection cover on top. An 11" clutch is a truck item, not the best choice for your hot rod, but it should work without the issues you have. Perhaps a truck throwout bearing retainer is different? again, look thru the hole and see whats happening
    Bob Lowry likes this.
  3. rusty valley
    rusty valley
    another thought, wrong arm on the trans pivot point, or in other words wrong leverage ratio for the travel required.
  4. 29ron
    29ron
    The free play is about 3/4” to 1” before the throw out bearing engages the pressure plate arms.
