(2) Rochester 2GV carbs (Divorced choke) -Both carbs are pre 1968 production (No production dates on casting body) -One carb has the pre 1968 metal ID tag (Production date of May 1964) -Both carbs feature side fuel intake -Originally used on small block Chevy engines Both of these carbs need a chemical bath and full rebuild, obviously. None of the moving parts are frozen. Yes there is surface rust on the bases but they will be fine after clean-up. -Great for a tri-power setup? Selling together as a pair for $100 + shipping. Paypal verified. These should both fit in a USPS priority mail "large" box, shipping cost of $19.95 to all 50 states. Happy to ship world-wide. ***NOTE *** There are 3 variations of the Rochester 2G carburetor (2G, 2GC, 2GV) The choke assembly is different between the 2G, 2GC, and 2GV models. "Choke operation of the 2GV carburetor used a thermostatic spring mounted to the manifold, and was connected to the choke valve via a linkage rod. 2GV - Divorced Choke (choke thermostat is mounted in the intake manifold)" This is everything I know, I am not a carb expert, just a hot rod junkie.
