Projects 25 T roadster gow job build
Discussion in 'Traditional Hot Rods' started by olskool34, Sep 13, 2013.
  1. Squablow
    Squablow
    I think those are MG/Triumph knock-offs. Neat idea.
  2. Hey those look like early 30's Chevy shocks. I have a set on the back of my T. Also running Houdailles in the front. Looking GOOD!!!
    Sent from my SAMSUNG-SM-G730A using H.A.M.B. mobile app
  3. olskool34
    olskool34
    I think they are Ford, they have part number F-745 on them.
  4. Ahhhh good to know!
  5. olskool34
    olskool34
    From what info I have found they are 41-48 ford but not sure of application. Finished up the caps today and put them on. I think they are staying.
    Outback and DylanHill1931 like this.
  6. That looks soooo BOSS!!!!!
  7. Look like keepers to me. JW
  8. olskool34
    olskool34
    Yeah I like them. I like the stock A caps but with 21" wheels, the stock cap is all there is. I wanted something different. Hopefully winter will end here in Michigan sometime soon. Snow flurries today and still cold until next week. All I can work on is stuff that I can bring in the house.
  9. olskool34
    olskool34
    Posted using the Full Custom H.A.M.B. App.
    Spring is here!
    Outback and brEad like this.
  10. Nice picture!!! I love this car!!!
  11. olskool34
    olskool34
    Spring is finally here. Got the coupe moved out and the T in the garage. Need to get some things done that I have been neglecting. First was the firewall. The stock T firewall did not come down far enough to meet the floorboard so I took the firewall out and added about an inch to the bottom. Now the floorboard rests up against it. Also got the shell mounted to the A radiator.
    I went to the Eastside A's swap with a few buddies and I was looking for certain things. Only came home with two but only spent 9.00 dollars so not bad. First thing was the mirror. I didn't want to buy a reproduction mirror so I found this one for 5.00. Cut it up, added a curved piece of tube to it and fastened it with a model A terminal nut.
    Last thing that was bugging me was the upper water inlet. I had to make them match up and I think I finally have it. Both the neck on the radiator and head have been angle cut and welded up to match. Again, making the radiator a straight neck when I had it re-cored would have saved tons of time...
    Also a small thing but I found some original A headlight conduits so I drilled the shell for some grommets and mounted them up.
    Lastly some random pics that I took while shuffling cars. Kind of getting a Stroker Mcgurk feeling to it to me.
  12. Skobie
    Skobie
    from Philly
    subscribed - love it!
  13. Now that looks sharp !!!! JW
  14. banjorear
    banjorear
    Awesome. Great job!
  15. This is the best build on the HAMB right now!!
    Outback likes this.
  16. olskool34
    olskool34
    Lol! I appreciate it Tiny!
    Got the rear shocks done today. They are ford but unsure of year. They work and they helped the back end a ton.
  17. olskool34
    olskool34
    First coat of black. ImageUploadedByH.A.M.B.1396832315.488612.jpg ImageUploadedByH.A.M.B.1396832337.358464.jpg
    Dannerr likes this.
  18. ss34coupe
    ss34coupe
    The black paint looks good!
  19. Outstanding! You don't waste any time do you?!?!
    Looking forward to more!!
  20. Millhead
    Millhead
    Wow! Your T is really coming along nicely. Love those knockoff's they turned out very nice, I might have to steal that idea, if that's ok with you. I need to fill the hole on mine and keep the stock caps underneath them.
  21. olskool34
    olskool34
    Thanks guys! I hate fake patina but on this car I want the finish to look like it is an old aged paint job. I thinned some black and brushed it on thin. I am now in the process of using green 3M scothbrite pads to break through the black a bit, not too much though. Going a little heavier on areas where there would be more constant contact. Then I will try and buff it out. We'll see.
    Dannerr likes this.
  22. Bugsy
    Bugsy
    from Kansas
    This looks amazing. She's really coming together. LOVE IT!!!!!!!
  23. flatheadpete
    flatheadpete
    from Burton, MI
    Dang.....See you at Sins I hope.
  24. olskool34
    olskool34
    That's what I'm shooting for Pete, see ya there!
  25. Everything is just right !! JW
  26. olskool34
    olskool34
    Some pics from today. It looks a ton better in person, my camera can't really capture what it actually looks like. I am aging it a bit, and polishing as I go. I think it is going to look correct for this old gal. I used rustoleum gloss black and thinned it down a bit, wet sand it a tad to show the brush marks and polish. Still a ways to go but getting there.
    DylanHill1931 and Dannerr like this.
  27. Freaking LUV IT!!
  28. bct
    bct
    nice work . looks like it should
  29. flatheadpete
    flatheadpete
    from Burton, MI
    Even the dog has to sneek a peek! Looks fantastic!
