I pulled the 1970 350 out of the '65 today in preparation for the original 327 to go back in. After pulling the pressure plate and disc, I saw the flywheel. Seems to me these are heat cracks, or something like that. Is this flywheel wasted, usable, or in need of turning? Thanks in advance.
It's junk. It would better suit you as an anchor. There is way to much heat checking and it looks like it's blued.
there are always guys who say buy a new one---take it to a good machine shop and let them resurface it or junk it---that type of surface is very common on flywheels that get abused...
if its blued don't take the chance , buy a new one , when we machined them at the shop , if you could catch your fingernail on it or had blue ( annealed) or black spots ( hardened ) , it was scrap metal , if it was brown to yellow it was ok to cut .
If you compare the cost of a new flywheel with the cost of just the mechanical and body damage that occurs if it explodes, it is no contest. And that is just vehicle damage ....your feet and legs , and those of a passenger, are way more valuable than a couple hundred bucks, if that much.
Those look like they're pretty deep. I suppose you could get it ground and see what it looks like, but pretty sure that would just be wasting money.
Thanks, guys, I appreciate your knowledge and wisdom. It's the original unit (as far as I know), so I'll keep it around the shop for posterity (and maybe for shop art or a base for something), but Corvette Central has a new one for a decent price. I'll have to call to see where it's made. Thanks again.
Thank goodness you found that before a nasty event! Even if you could resurface it, that takes metal (weight) away from its' designed purpose of smoothing engine rotation.
Last fall I was at my local scrapyard when I noticed the owner throwing a bunch of scrap in a gondola. He was throwing out a bunch of old flywheels and pressure plates that he had been saving for years. These were flywheels, not flex plates. I went thru 'em and found 8 really good ones (all chevy). He took $50 for the whole lot. 6 small ones and 2 big ones. Took 'em home, cleaned 'em up, and sprayed 'em with oil. Threw 'em in an old plastic tote and put 'em in storage. Actually there were only a few of these that were cracked so bad they were junk. The one you got don't look good.
