Technical Mopar 727 speedo cable to Autometer
Discussion in 'The Hokey Ass Message Board' started by kustomolds, Mar 16, 2014.
  1. kustomolds
    kustomolds
    Anyone know what cable to use for a Mopar 727 tranny to an Autometer gauge??
  2. squirrel
    I'd try to find an earlier sleeve for the transmission, that has 7/8" threads on it, and use a normal early Chevy cable.
  3. kustomolds
    kustomolds
  4. scootrz1
    scootrz1
    from usa
    I cut two cables and welded together for my mopar 4 speed is real accurate tested with my GPS running watch for miles gone
  5. gimpyshotrods
    gimpyshotrods
  6. squirrel
    no, I just grabbed a picture using google.
    I have a few in my spare speedo gear parts bin.
  7. squirrel
    $132? wow....I guess that's why I suggested using some common parts that you can get cheap
  8. I have done this before - from memory my factory cable fitted right up to the Autometer speedo.
    Rat
  9. tim o'connell
    tim o'connell
    bobs speedometer service in mich can also help you . they can also give you a calibration box so the speedo reads correctly for different gear and tire sizes . its pretty slick all you need to do is attach a cable with a flag to count the number of revolutions , roll the car 52'9" give them the count and your speedo will be spot on ! they're number is 810-632-0400 . hope this helps
  10. e1956v
    e1956v
    Alliance Vendor
    I can make the speedometer cable and housing up for you no problem, just give me a length.
