gauges
Discussion in 'The Hokey Ass Message Board' started by bbrix, Feb 3, 2014.
  1. bbrix
    bbrix
    from idaho
    The gauges in my 62 unibody have gone bad. I tested them yesterday. I would like to go from the 6 volt sluster system to a 12 volt. Are there gauges that are compatible with my cluster?
  2. 302aod
    302aod
    from Pelham,Tn.
    62 was 12 volt and no, you can just get an aftermarket gauge cover and install regular gauges.
  3. bbrix
    bbrix
    from idaho
    Sorry, yes this is a 12 volt system, but aren't the temp and gas gauges 6 volt and a cluster voltage stabilizer is used to reduce the voltage? Thanks 302aod for the input. The original gauges are much more expensive that I had hoped and thought I could replace the old gauges for upgrades in the same cluster location. bob
  4. squirrel
    just curious, how did you test the gauges?
  5. Yes, it seems odd that ALL of them went bad at once. :confused:
  6. ThomasN
    ThomasN
    from spokane wa
    off subject but is there a 6 volt pos gr gauge available for my 53 vic after market cluster?
    Thanks
  7. You are better off starting your own thread so its seen.
  8. bbrix
    bbrix
    from idaho
    I tested gauges with two d cell batteries in series. Put them together and checked with a meter. Had power, but no movement in gauges. The voltage stabilizer is shot. It actually smoked. Thinking it took out gauges because they worked, sort of, until that point.
  9. squirrel
    what did you have connected to the sender terminals on the gauges?
