Projects Introducing the Roofus Special
Discussion in 'The Hokey Ass Message Board' started by Flipper, Mar 1, 2009.
  1. Yes, build control arms like on the 1930's Miller Indy cars
    87 vote(s)
    67.4%
  2. No, go with a Ford style straight axle
    42 vote(s)
    32.6%
  1. farna
    farna
    Everything should work just right then!
  2. Flipper
    Flipper
    from Kentucky
    Looks like there is a pretty good chance that I will get to work on my a-arms this weekend.
    Hopefully it will be mostly doing and not as much figuring out what to do. :)
    Two productive days and I should have a rolling chassis.
  3. Flipper
    Flipper
    from Kentucky
    Before I got too carried away, I decided to mark up the second batch of a-arm parts
    I started on the angled piece this morning
    figure out where to trim
    trim
    add some back?
    transfer new cut lines
    weld
    grind
    admire
    grind some more (first arm)
    grind some more (get rid of open end wrench shape...oh yeah, I welded on the corner pieces too)
    start on the next one...
  4. rottenleonard
    rottenleonard
    Shouldn't you use metric wrenches with mercedes parts?
  5. BuiltFerComfort
    BuiltFerComfort
    Just asking, not criticizing: Will those welds be good enough, with the different steels and all? And is that enough strength in the arms themselves? Visually it looks iffy but that's my untrained eye.
  6. Flipper
    Flipper
    from Kentucky
    The arms themselves are beefy as hell. ...the welds look good. Everything was V'd so I got 100% penetration and as much surface are as I could. It should be fine for garage art :)
  7. Flipper
    Flipper
    from Kentucky
    Well, no rolling chassis this weekend either... The idea I had for making the attachment to the balljoints wasn't going to work. Time for a plan B.
    I did do something constructive though.
    The last time I moved the car, I did something stupid. To balance it on the chain hoist, I ran the chain around the dash bar and the firewall bar. The leverage pulled the dash bar forward and damaged the frame.
    Well I worked on making the frame stronger.
    First, I cut out the damage and welded in fresh metal.
    Then I came up with a reinforcement plate to spread the load out (more cop car metal)
    glued in
    seriously glued in
    top surface ground down
    I still have to do the other side....
    Next time, I won't lift the whole car by the dash. Engine and trans are coming out.
    kidcampbell71 likes this.
  8. Hi Flipper, always a sight to see how you're working! pretty unique and you must have a huge amount of imagination!! i saw a lot of cool solutions while you're building this, i'm looking forward to see how this car will come out! this will be a one-of-a-kind car, i'm sure! keep on and thanks for let us watch your build. ;)
    Cheers, Carsten
  9. Airhead Roadster
    Airhead Roadster
    This A-arm part of your build is my favorite thus far! Keep up the great work. Thanks.
  10. Tin Indian
    Tin Indian
    I hope this leads to something more than garage art. I wanna see this thing go down the road. Youve worked too hard not to drive it.
  11. ThiBuilder
    ThiBuilder
    This build is awesome! The project is just so unique, it makes me excited!:D Seems I have a future project on my hands. Great build for sure!
    Also, any updates? It seems like it's been a while... Keep on Rollin!:cool:
  12. Flipper
    Flipper
    from Kentucky
    The wife had dibs on Easter weekend. Hopefully I will get to work on it this weekend.
  13. Flipper
    Flipper
    from Kentucky
    I worked on figuring out what it will take to get the upper a-arms attached to the frame.
    I cut these from a piece of 2x4
    so that I could do this
    The idea is to mount the mercedes shafts on plates so that the arms can be bolted to the frame. The problem is that the frame is not square with the world...the rails are pinched.
    The arms need to be mounted at an angle.
    simple enough...in theory
    now to make it pretty
    make mirror image one too...
    [​IMG].
    Next step will be to prep the front rails for the arms.
  14. Flipper
    Flipper
    from Kentucky
    Oh yeah, I'm thinking about doing slots in the a-arm mounts for caster adjustment.
  15. Flipper
    Flipper
    from Kentucky
    Hopefully I will get a chance to play over the holiday weekend.
  16. cmarcus
    cmarcus
  17. Flipper
    Flipper
    from Kentucky
    Welded up the other a-arm kit
    and one of the mounting brackets
  18. greenehoosier
    greenehoosier
    I have been following since the beginning, I hope to see this on the road someday. Updates?
  19. Flipper
    Flipper
    from Kentucky
    Nope. Nothing to report. I'm waiting for cooler weather.
  20. Flipper
    Flipper
    from Kentucky
    Please bear with me...i'm swapping the pictures over to Flickr from Photobucket. It is going to be a bitch to do, but I'm sick of Photobucket
  21. wrsexton
    wrsexton
    Since I just found this thread today, I now understand why I can't see the last 3 years worth of photos! Guess I can only hope you change them over soon. What little I've seen is awesome!
    Charliechop likes this.
  22. Flipper
    Flipper
    from Kentucky
    Holy crap, I posted a lot of pics when building this thread! I've swapped out build pics to post 400. The reference pics will be the last things to track down.
  23. jaksno
    jaksno
    from Norwood CO
    Cooler weather has arrived! Any updates?
    Take care,
    Jackson
  24. damnfingers
    damnfingers
    Good question....surely something's been done?
  25. Flipper
    Flipper
    from Kentucky
  26. stealthcruiser
    stealthcruiser
  27. Flipper
    Flipper
    from Kentucky
    I'm planning on spending a week at Dad's house during Christmas shutdown. Hopefully I can split my time between Roofus and the Dodge ......and get a little something done on both!
  28. jr9162
    jr9162
    Any more progress?
  29. charliechaindrive
    charliechaindrive
    from staples mn
    Just got done reading through this thread, wow!! I admire your use of salvaged and repurposed materials, hopefully an update will be soon. Can't wait to see more!
    Charlie
  30. Flipper
    Flipper
    from Kentucky
    I think I finally figured out an elegant way to mount the a-arms to the ball joints. Next trip to Memphis, I will find out if imagination and reality are all that close.
