At one time i had a chart. The chart had metric sizes which were broken down to regular sizes....G7815...then width...tread...overall...etc. any ideas where to look would be great. I have all over the internet. Thanks, RCM
This is great, I can really use this. BTW, Summit allows you to search for tires by just about any criteria, such as overall diameter, tread width, etc. Even Tire Rack doesn't do that.
I don't like those charts as you usually end up with a visually smaller tire. If that's what you want, fine. But if you're trying to match OEM or a older size, your best bet is to look for a diameter match first, then width. You usually need at least two sizes bigger to get a visual diameter match...
