Timing this little 352ci ford
Discussion in 'The Hokey Ass Message Board' started by matysik, Aug 24, 2013.
  1. matysik
    matysik
    First off, parts on the motor that aren't stock.
    -Hedman headers
    -edelbrock performer intake manifold
    -holley 750 carb (not a double pumper)
    -MSD 6al box
    -12% over stock cam (this is where Im getting stuck, p.o. had no part number or specs on the cam, 12% over is all he knew.
    Since I got the car it has had a lazy initial throttle and stumble.
    1) unplugged vac. Advance from carb and capped port on carb
    2) started the car up and checked initial timing to be at 35-40 degrees BTD!
    3) started to move dizzy to set timing by ear and it starts to stumble hard once you get anywhere near about 25 BTD
    Looking for input so I can get the timing dead on so I can finalize the tune on the carb
  2. Some things to check....
    Is the cam installed right? If the timing is off one tooth, you'll never get it right.
    Are the timing marks in the right place? Ford did move the marks around, if the damper/timing pointer don't match you'll have to find TDC and remark the damper.
  3. JohnEvans
    JohnEvans
    from Phoenix AZ
    Initial timing at over 30* WTF!!! At idle speed somewhere between 8 & 12 with vac disconnected is what you want. Something around 34-36 at 3000rpm would be a good place to start. And yes incorect cam install can cause all sort of issues.
  4. hoop98
    hoop98
    from Texas
    And be sure #1 i marked right on the balancer.
  5. RidgeRunner
    RidgeRunner
    from Western MA
    Said it before on here someplace but I'll say it again, check for a worn timing chain. Pull a battery cable and the distributor cap, bar the eng back and forth with a breaker bar or big rachet and socket on the crank bolt in front, watch for a delay in rotor movement in relation to crank movement. Mine drove me 1/2 nuts before I figured it out back in the day, PO had put a bunch of time and bucks into the motor but reused the old chain.
    Ed
  6. FrozenMerc
    FrozenMerc
    The guys above have given some great advice on things to check for the timing. However, you are probably quite over carbed. When I built my 352, I brought both a 600 cfm Holley and a 750 to the dyno session. We fiddled around quite a bit with the 750, and it was always giving up at least 20 hp to the 600. Some of the throttle response issues may be simply having too big of a carb on the motor.
    Good Luck.
  7. TooManyFords
    TooManyFords
    from Peotone IL
    pull #1 plug. Get it at to dead center ans see if mark lines up with pointer. Yo may have a bad balancer.
  8. Ole don
    Ole don
    Often, an engine with those changes cant be timed with a light. Use a vacuum gauge, then if it starts and doesnt ping, use the light to see where it is. A smaller carb will give throttele response down low where the motor runs, in a heavy car to big a carb will never run slow.
  9. matysik
    matysik
    Checked for this and I'm good to go here, no delay
  10. matysik
    matysik
    Did this and the timing marks are dead on to the pointer at the tdc of cylinder 1
  11. matysik
    matysik
    As for this I just picked up a 600 but am looking for a place to hot tank it before I rebuild it. Once its together its going right onto the car
  12. Just curious if you are familiar with Ford engines very much. Unlike a Chevy, number 1 cylinder is the first cylinder on the passenger side, rather than the drivers side. My first Ford FE project was a 66 Fairlane GTA, and it was not as fast as I thought it should have been until I started checking the timing on the correct plug wire!
    If thats not the problem, I`d do a compression test, if the numbers are low, under 150psi, I`d be looking at the cam timing, as others have suggested.
  13. birdman1
    birdman1
    are you running a point distributor? If so, the plate that the points mount on is ussally worn at the pivot point on older Ford distributors. the worn pivot point also messes with timing. 750 is not too big with a better cam, this is NOT a 350 Chevy!! Ford FE engine have much better flow of air than Chevys, so a bigger carb is want they eant. Your problem is ignition, not fuel. Do you testing in orde, start with a vacuum test to make sure there is no leaks, you already tested the chain and said it is good. Dampner could have slipped like was mentioned. If you can by-pass the MSD, do that before you go too far, it can cause problems also. Just my 2 cents, probably not worth that!!:p
  14. sunbeam
    sunbeam
    Did you use the positive stop other methods are not very accurate?
  15. terryble
    terryble
    from canada
    You don't mention what year of 352 you are dealing with, they were used from 58 to sometime in the mid/late sixties with a lot of different cams and compression ratios. Mild stock cams could have more than .400 lift and 200 degrees of duration that loosey goosey 12% over could mean you have .450 lift and 225 degrees of duration and a stock PI or T-Bird cam from the era could be .440 lift so your 12% over would be around .525 thats a lot of cam in any street engine. Manifold vacuum could be an issue.
  16. rfraze
    rfraze
    Time to highest manifold vacuum. Mark distributor to block. Test drive.
  17. matysik
    matysik
    Yes I am aware of this
  18. matysik
    matysik
    For this parts combo with stock "choked" heads 750 is far too big.
    Not running points on this car.
    Vacuum test holds steady at 17 and to really check the dampner I have to pull it off and make sure the timing marks are lined up inside the timing cover first with the cam install from the P.O. to be positive that isn't any part of my issue too.
  19. matysik
    matysik
    Yes I did
  20. matysik
    matysik
    Motor is a 66, manifold vacuum holds steady at 17
  21. matysik
    matysik
    I did this a while ago, but still have the same drivability issues and then can't confirm where I'm really running for timing on the motor
  22. Model A Gomez
    Model A Gomez
    I rebuilt a 390 with a mild cam, petronics dist. and Edelbrock 650, timed at 15 degrees btdc and runs great. sounds like you have a lot of advance to me.
  23. sunbeam
    sunbeam
    You might check cam timing try pulling the valve cover on number 1 turn it to tdc exhaust. The exhaust valve should be almost closed and the intake just opening at TDC. One tooth off is about 15 degrees.
  24. R Pope
    R Pope
    sunbeam beat me to it! Split overlap #1 and check the damper mark, should be right on.
  25. texoutsider
    texoutsider
    from Frisco, Tx
    yep...that is the first thing that I would check
  26. matysik
    matysik
    Pulling the timing cover tomorrow hopefully, followed by multiple days of single digit weather
  27. matysik
    matysik
    Stuck here now since I can't find my puller. Ordered a new one today instead of renting one so will find out the cam and timing for sure in a few days when it arrives.
    Thanks for all help and tips so far guys
  28. Dan Timberlake
    Dan Timberlake
    If I have a TDC mark I can trust its pretty easy to "degree" the cam just pulling the valve cover. I'd hate to pull the timing cover just to look at the marks on the timing set. Plus, more than once the marks on the timing set were wrong, and a few times just misunderstood.
    The 1959 Ford Edsel factory manual has a procedure for checking cam lobe lift and cam timing with the engine assembled, in the vehicle.
  29. matysik
    matysik
    True, but I don't have anything to identify the cam, no brand, I.d., nothing so that is the other reason the cover needs to be pulled.
