Projects 1940 Ford Coupe
Discussion in 'Traditional Hot Rods' started by clips221, Dec 17, 2013.
  1. MBog
    MBog
  2. fatkoop
    fatkoop
    Great find! If you've never owned a '40, you'll be surprised how nice a car they are. Just fix the basic things to make it road worthy, no need to go overboard, stock steering and brakes are fine if in good shape. Get it running, get it driving and enjoy! I put many thousands of miles on mine every year with all stock running gear and a '62 283.
  3. Congratulations. Have fun and enjoy the ride.
  4. 1941coupe
    1941coupe
    in my opinion the 1940 ford is the best looking ford that henry ever made,keep the flathead if you can and never sell it you will regret it later if you do, ask me how I know...best of luck with it
  5. Nice find. Get it running and enjoy it for next summer then start work on it next winter .
  6. joel
    joel
    Get it running and remove/preserve as many of those rust areas as you can. The longer you look at those, the harder they are to fix. After driving with the stock brakes, trans, rear and flathead for a while you'll know what you want to change, if anything. It looks like it may have a 4dr front seat. Great find.
  7. 49ratfink
    49ratfink
    Fords best looking car of all time in my book.
  8. Jake H.
    Jake H.
    Subscribed!
    I'm looking forward to seeing this one progress. What a great start.
    I was lucky with mine, and did exactly what you describe as planned (well, just getting around to patching floors, this winter). They are a nice driving car, right out of the box.
    My only advice is to keep it simple and work with what you have (my own mantra that gets challenged often).
  9. racinman
    racinman
    Nice! I was also looking at it on CL... enjoy, it looks like a good one!
  10. 40fordtudor
    40fordtudor
    I blew the motor in my '40 coupe back in 1959---I sold it right where she quit. I was going to go out and buy another one; RIGHT. I'm on no. 5 (Avatar) and no coupe since '59.
  11. olscrounger
    olscrounger
    have had quite a few and won't be without one --my favorite Ford-good luck and pts aren't that difficult to find.
  12. clips221
    clips221
    Headed To pick up the 40 afterwhile. Can't wait to get it home and in the shop....
  13. clips221
    clips221
    Got it home. Dang now I gotta make room.
  14. MERCURYGUY
    MERCURYGUY
    You will love it I had a deluxe all original. It drove light a dream. On top of it the 1940 Ford is an all time favorite.
  15. two couped up
    two couped up
    from pa.
    Get it on the road and let the fun begin. I've had mine since 1972 and till death do us part.
  16. clips221
    clips221
    Got a couple valves stuck in the flathead. If the engine needs rebuilt I'm wondering whether to rebuild it or drop a sbc in it...
  17. dclickster
    dclickster
    Congrats ! I'm envious ! Have a good time on the build.
  18. clips221
    clips221
    who has the best fitting patch panels for the 40 coupes? needs door bottom's, bottom of the panels behind the door, and a good bit of flooring patched. I worked on it in my sleep all night long. :D
  19. KStewart
    KStewart
    I always wanted a 1940 Ford but I did not get one until late in life. I was born in 40. I had several 39's but not a 40. Now that I have one I am happy now. Wish you luck with yours.
  20. richie rebel
    richie rebel
    nice car,good luck with it..........
  21. Jake H.
    Jake H.
    lothiandon1940, I was just watching Thunder Road, and Niles Pendlin drove the '49 Olds coupe. Jed had the '40 coupe...
    I can't wait to see this car get underway!
  22. clips221
    clips221
    Floor pans are very rough. The bottom of the Rear door jams are rusted away from the body. Looks like I have more work ahead of me than I thought. It's all good...
  23. .....Thanks, I think you are correct, I believe it was maybe Jethro Moultrie.:confused:....aka, Jed.
  24. Was this the coupe that was advertised on Cl,,I believe it was in Pickens. HRP
  25. Jake H.
    Jake H.
    The floors and quarter patches should be available through EMS, Dennis Carpenter, Bob Drake, etc...
    Really common rustout areas. Check under the cowl sides/firewall/front body mounts. The trunks and rear roll pan areas are also usually hammered in these cars, if they sat outside at all.
  26. clips221
    clips221
    That's the one HRP. it was in Pickens. Was originally bought in Belton SC
  27. clips221
    clips221
    Was hoping the engine would just need cleaned up to run but that's not the case. Valves were stuck and very rusty. One piston journal is scared up pretty bad also. Gonna pull the engine and transmission this week.
    Being that I've gotta rebuild an engine, the question is whether to go with a SBC or stay with the flathead.. Decisions, Decisions...
  28. Saxon
    Saxon
    from MN
    Sbc is a great engine... But! Yblock it if the flathead is out. Or find a decent used flathead with some wear, install it, and wear it out.
  29. metal man
    metal man
    Nice find there.
    When it comes to the rear body panel below the decklid, Drake's fit the best, and I've used them all. Everything else, I make myself, so I can't speak for.
