Been on a mission to get all the stuff gathered up for my model a which has been dubbed the 668 (neighbor of the beast) by my stepson got my engine trans 32 frame and went and picked up my eBay quickchange this is where shit got weird. I never noticed till I had it home for three days two little facts about it one its too wide no biggie we shorten the tubes get a set of axles right? The I noticed not only is it too wide its offset five inches and the one tube is shorter than I need to make it right lol so getting new tubes and axles before I even start mockup. Going with hairpins on the front and Pete&Jake's ladder bars out back with the model a cross member and spring moved to the front and a few leaves taken out is the plan was gonna use my v8 60 axle but I think I'm going with a dropped and drilled I beam this go around on The front still can't decide how to steer it yet. With the banger in it ill have tons of room but just don't have a clue which way to go yet like cross steer but the f1 box looks so cool. Decisions decisions.......
Here.I will let you borrow some periods and commas. ...... ,,,,,,. You can give them back after you use them. Btw, it sounds like a bitching project. Cheers! Posted using the Full Custom H.A.M.B. App!
Its a winter's out of a dirt track car.it was offset and I never caught it till I got it home. As for the 668 its not evil enough to be the beast but could be evil enough to live next door to him. Thus 668 next door neighbor to 666.
Shorten the long side of the rear end and the offset wont bother the drive line if you have drive shaft clearance. Gary
Don't bother centering the pinion - unless you just want to for aesthetics. As stated above, it won't matter to your driveline. We've all seen how to set up pinion angle. Diagram below. The concept is also valid in the horizontal plane (just imagine you're looking down at this pic). Hope that makes sense....
Correct, and next door would be 664 or 668. If you were thinking it was 667 that would be across the street. All this is in a bad neighborhood.
I laughed a little. I think it would look wierd offset. You can get all the stuff from winters. I got axle tubes with new bells on them as mine were bent, supposedly. Anyway its all pretty reasonable from winters..
That neighborhood is one that I have never figured out why anyone would want to visit. Posted using the Full Custom H.A.M.B. App!
