Projects 54 4dr BelAir build!!!
Discussion in 'The Hokey Ass Message Board' started by Jbuhl1954, Sep 21, 2013.
  1. Jbuhl1954
    Jbuhl1954
    Got the floors basically done ol Merlene!!!
    Then I decided I should put the suspension on air!!!
    Cut all out!!
    ImageUploadedByH.A.M.B.1379809694.838237.jpg ImageUploadedByH.A.M.B.1379809711.709330.jpg ImageUploadedByH.A.M.B.1379809724.536265.jpg ImageUploadedByH.A.M.B.1379809745.685142.jpg
    Not bad haven't put down any beads in about 6 years!!!
    ImageUploadedByH.A.M.B.1379809808.328244.jpg ImageUploadedByH.A.M.B.1379809816.727980.jpg
  2. Jbuhl1954
    Jbuhl1954
    Start back on her tomorrow!!! Ill get more pics as I go!!! ImageUploadedByH.A.M.B.1379809876.814332.jpg
  3. 5559
    5559
    from tn
    looks like a good start
  4. 56gasser
    56gasser
    from lower al.
    Looks good! But you need to take good pics, cause I am doing the same thing this winter.:D:D
  5. Jbuhl1954
    Jbuhl1954
    Ya 56 gasser I'll take as many as possible!! More of a worker then a photographer!! Lol!!!
  6. Jbuhl1954
    Jbuhl1954
  7. Jbuhl1954
    Jbuhl1954
    ImageUploadedByH.A.M.B.1380655728.544199.jpg ImageUploadedByH.A.M.B.1380655754.011996.jpg ImageUploadedByH.A.M.B.1380656029.003869.jpg ImageUploadedByH.A.M.B.1380656041.382593.jpg
    Posted pics again cause they would not post!!
  8. Jbuhl1954
    Jbuhl1954
    Got the parallel 4 link and panhard rod tacked into place!!! ImageUploadedByH.A.M.B.1381850260.331019.jpg
    Took 2x3x3/16 square tubing and tack to frame to space 4link out!! And yes it will all be gusseted!! ImageUploadedByH.A.M.B.1381850358.232081.jpg
    Other side!!
    Passenger side in place!!
    Both links on!!
    And panhard rod on!!! Bag set up coming next can't wait!!!
  9. Jbuhl1954
    Jbuhl1954
    Oh it's gonna be low to the ground!!! Love this shit!!! ImageUploadedByH.A.M.B.1382043679.200992.jpg
  10. Jbuhl1954
    Jbuhl1954
    Here is what I got done tonight!! Lower and upper bag mounts tacked in place!! ImageUploadedByH.A.M.B.1382061461.358391.jpg ImageUploadedByH.A.M.B.1382061473.882531.jpg ImageUploadedByH.A.M.B.1382061504.624225.jpg
    Tomorrow I'll tack up the upper cross bar and shock mounts!! Pics to come!!
  11. hudson hot rod
    hudson hot rod
    Wow! great work and the pictures are top notch! keep em coming, I'll be tearing into my 54 this winter too and will probably be "borrowing" some of your ideas! :D:D:D
  12. Jbuhl1954
    Jbuhl1954
    Ya thanks man!! I'll keep pics coming!! Borrow all you want that is why I put them on here!! I love getting new ideas from other hambers, so I enjoy showing mine!!!
  13. JakeDW
    JakeDW
    from Missouri
    Gona look good on the ground.
    Jake
  14. Jbuhl1954
    Jbuhl1954
    I think everything looks a little better on the ground!! Yessir!!!
  15. RatPin
    RatPin
    The more-door revolution is coming!
    Nice work!
  16. Jbuhl1954
    Jbuhl1954
    Ya bro for sure it is!!! My pops had one back in the day!! So when I found this one had to get her!!
    More door revolution!!!!! 👍👍👍
  17. Just curious, why are the bags positioned so far inboard? Like springs, wouldn't they be best positioned close as possible to the frame rails? Only asking as I have yet to do this on my 53 Buick...have never bagged any vehicle before.
  18. Jbuhl1954
    Jbuhl1954
    Dragdoc I put them a little closer in then I do most!! If you look closely the edge of bag is on the edge of the parallel link bars. The panhard bar will keep the car from side to side play!! I will be running independent bag setup so should not have any sway issues either!! ImageUploadedByH.A.M.B.1382100045.010156.jpg
    I also slipped these bags in a little closer and actually behind the axle and this s10 drove like a champ!! So I figured it would work for my application!! Thank you for the close eyeball!! I second opinion is always nice!!
  19. Jbuhl1954
    Jbuhl1954
    Also Dragdoc it is all just tacked in place if I don't like they way it travels when testing ill redue it!! But I think it will be ok!!! Thanks again!!
  20. Jbuhl1954
    Jbuhl1954
    Alright back in the garage!!! My boss gave me some grid wall so I put it up the other day!! Great addition to the garage!! ImageUploadedByH.A.M.B.1382576775.037543.jpg
    But on to the good stuff!!
    Bending up some crossbar and shock mount pieces!!
    Crossbar tacked up!!
    Frontside!!
    Put the bags in it!! Bottom bar is tacked to the parallel link mounts, ill use it for my lower shock mounts!!! I'll try to get the shocks done up and finish weld everything before Monday!! I'll take more pics along the way!!!!
  21. Tricky53
    Tricky53
    from Bend, OR
    Nice build! Can't wait to see it completely laid out!!!
  22. Jbuhl1954
    Jbuhl1954
    Ya thanks a lot Tricky53!! Soon!!!
  23. slosteve
    slosteve
    You lay down a nice bead, too.
  24. Jbuhl1954
    Jbuhl1954
    Lol thanks a lot slostev!!! It's been awile for me but I having a good time!!! Thanks again!!
  25. Jbuhl1954
    Jbuhl1954
    Alright so I took a little break on the car but am back at it now!!!
    Got the shocks tacked up and ready!! ImageUploadedByH.A.M.B.1383323029.896406.jpg
    Tested all the travel lengths and then put her on the ground!!
    Here is the pic I like the most!! The comparison pic!!! ImageUploadedByH.A.M.B.1383323227.151168.jpg
    When I pulled her in the garage and how she sits now!!! MII front end coming next!!!
    #garagebuilt #builtnotbought
  26. freiertpc
    freiertpc
    you choose to weld the bag mounts just on top of the notch instead of a more professional approach? i.e loose un-terminated ends of bars? Ive been building mini trucks since before bags were "the thing" and if you really want to knock it out of the park clean up those ends and throw some gussets on it. I'm not saying bad job just offering advice Most dont even make it this far, thats when i buy them by the box.
  27. Jbuhl1954
    Jbuhl1954
    I don't know man looks pretty profesh to me!! I appreciate your comments and advice???? But the car isn't done yet there is lots to do still!!! So check back and hopefully I can build "MY" car to your liking!!!
  28. Jbuhl1954
    Jbuhl1954
    So I haven't worked on Merlene much lately due to the fact my wife was diagnosed with stage 2 breast cancer in November... She is in her second round of chemo.. 4 more to go!! Once we get everything back in order(life) I will be getting back on my build!!
  29. engine138
    engine138
    from Commack NY
    Family first everything else second keep the faith and good luck to ya
  30. Jbuhl1954
    Jbuhl1954
    Thank you!! Yes family is always first!!
