My 55 only lights up the parking lamps up front in the first switch position. When the headlights (position 2) are on he parking lights go out. Is this by design? I have verified wiring and tested the switch. Thanks guys
If you want them to stay on with the headlights, put a jumper between the park light and the dash light terminal on the switch.
Umm..not sure why this was moved..new admin. I guess after 3 years of being an alliance member and 900+ posts I need to intro myself again...hi.. I'm Erik and I have a small car problem... Posted using the Full Custom H.A.M.B. App!
Thought about it a little bit and edited my post. If you jump to the dash light you will burn up the dimmer resister for the lights. Go to the tail light instead.
