Projects 1949 chevy bed
Discussion in 'The Hokey Ass Message Board' started by Flip8, Sep 25, 2013.
  1. Flip8
    Flip8
    Hey guys I'm 20 years old and rebuilding a hot rod my grandpa built back in the day I'm redoing the bed and wanna save the metal slats but it has the round head bolts and keep spinning won't come off I need some ideas on how to get them out without messing up the metal
  2. cut the nuts off the bottom under the wood.
  3. Flip8
    Flip8
    I tried with a cut off wheel and can't get in the the brackets are in the way
  4. 53 COE
    53 COE
    from PNW
    How about some pics of the truck, back in the day and now. Most def a keeper it it was your Gramps. Torching the bolts off could result in damaging the cross channels underneath. If the wood is rotten enough, knock it apart and out first - that will give you space for a cutoff wheel or sawsall.
    At any rate - slats are available repro - even in stainless......
  5. The bolts go through a retaining strip that hold the wood down to the bed,if you cut out the wood, you can access the bolt from the top. Split the wood with a chisel,cut it with a circular saw/ jig saw/ sawsall . Once you have the wood out of the way, you can hold the bolt with Vice Grips or even cut it out with a hack saw. Hope this helps
  6. Flip8
    Flip8
    I tried cutting out with saw and I don't have long enough vise grips to hold the head down and torch heated wood up
  7. Not the bolt, cut out the WOOD! Cut the bolt AFTER the wood is gone.
  8. Flip8
    Flip8
    I did I cut out the board so I could get to the bolt from the side
  9. 28 chevy
    28 chevy
    from NE Pa
    Weld a large nut to the head on the inside of the nut
  10. 53 COE
    53 COE
    from PNW
    Then you are well on the way - Just did this with my '53 - I did not use a torch at all. Do one board at a time, cutting bolts as you go. Do the boards on the side last - and replace them first - because they are supporting the bed too. Even bolt cutters might work once a board or two are out. Or just hold the middle of the bolt with visegrips and try the nut.
    When I removed the last rotten board and stood it up - even after all the prying and hammering - it had a nice black widow spider on the underside. :eek:
    Pics !?
  11. Flip8
    Flip8
    Alright cool thanks guys lots off good ideas I'll try this afternoon what kinda wood did you use 53 Coe
  12. 53 COE
    53 COE
    from PNW
    Simply knotty pine boards from used shipping crates free - didn't even route them for the strips. Good enough for now - if I ever repaint the truck - then it will be time for stainless strips and a wood kit. Hey the bolts are stainless now anyway. ;)
    Try out the BED WOOD VISUALIZER
    :cool:
      100.1 KB
      125.1 KB
  13. Flip8
    Flip8
    Ha I keeping the hot rod look black red and white so I was gonna paint the stops black and paint boards red and sand them down and put a sealer on em so the red stays in the grain
  14. 53 COE
    53 COE
    from PNW
    If you are using a wood with good grain like oak - try going over it with the red paint - then wipe it off with acetone while still wet. Saw Chip Foose do this but with black paint on his rebuild show to "age" the new wood in a '54. Wrote it down as an idea to try.
    Wear rubber gloves! And be outside or use a respiraotr and plenty of ventilation. Think safety young buck, so you can still be doing this 40 years later - that's how long I have been tinkering with old rigs.
  15. Flip8
    Flip8
    I'll try that idea I wan wanting to use some oak or redwood
  16. 53 COE
    53 COE
    from PNW
  17. Flip8
    Flip8
    Ill have to try it on a board laying around
  18. If you haven't got bolts out yet , hold nuts with vice grips so they wont spin and drill head out . Center punch , center drill and drill out with bit bigger than bolt . Good luck on project and make gramps proud .
  19. jetnow1
    jetnow1
    from CT
    1. A-D Truckers
    If using oak-use white oak rather than red oak- much more durable in exterior application. Jim
  20. Flip8
    Flip8
    Ok I've been shopping around for wood thanks for the advice guys
  21. Flip8
    Flip8
    ImageUploadedByH.A.M.B.1380248960.901799.jpg ImageUploadedByH.A.M.B.1380248973.822426.jpg
    Work in progress
  22. 53 COE
    53 COE
    from PNW
    Success! Looks like a pretty good shop you have to work in - with another rig or two.
  23. Flip8
    Flip8
    Ya grandpas shop lol with his 1939 ford sedan he has had since 65 a 1939 ford coupe and a 1940 ford sedan he is building
  24. 53 COE
    53 COE
    from PNW
    That's my kinda Grandpa - Learn all you can from him. :cool:
    My current '62 Dart project my Grandparents bought in 1969. And one of my first projects back in the day came out of their back alley in the summer of '75, a '41 Ford p/u. Here we all are with the '41 in the early '80's.....
  25. Flip8
    Flip8
    That's sweet my uncle has a 40 ford p/u
  26. Flip8
    Flip8
    Hey guys another question what's a good epoxy primer that ain't to terrible expensive
  27. 53 COE
    53 COE
    from PNW
  28. Flip8
    Flip8
    I used DuPont on my 36 frame but that stuff is crazy expensive so looking for a new route ill give it a try
  29. Flip8
    Flip8
    I got 10 1/6 boards what should I gap them
