30 Day Hath the 2013 September Banger Meet
Discussion in 'The Hokey Ass Message Board' started by Jiminy, Sep 2, 2013.
  1. Bluto
    Bluto
    I think you've been standing in the sun! :D Without a hat!
  2. Crazydaddyo
    Crazydaddyo
    Seems to be a lot of work for little benefit. Are you building an engine that will turn over 8,000 rpm?
    If you are only spinning @ 4,000 rpm, I don't see the advantage.
    I think money better spent would be a hard chrome crank and insert bearings.
  3. BCCHOPIT
    BCCHOPIT
    Why the hard chrome????
  4. Go right ahead the engine is yours. Just keep us up to date.
  5. Cool I'll check it out. Honestly I am 99%sure I want one of yours, but I like to look at all my options first.
  6. Crazydaddyo
    Crazydaddyo
    Harder surface = lower coefficient of friction
    Also, bearing surface will last longer.
  7. Brendan1959
    Brendan1959
    Closed or open drive?
  8. RoddyB34
    RoddyB34
    ,,,closed drive ,,will have to shorten TT and drive shaft about an inch and a half,,,
  9. Attached is a pic of my latest project based on a '25 T Tub which will use parts I have laying around including an A engine with a cam, dual carbs, ignition and a Winfield head, T5, 16" wires.
    Low buck - high fun
  10. racer32
    racer32
  11. skryla
    skryla
    from Brick, NJ
    Subscribed
  12. CA 31 Victoria
    CA 31 Victoria
    Does anyone know of any links to determine the historical info for the cast iron Mallory distributors? I have a YA 11a distributor (Model A) and have heard different dates for it's production run. One post suggested that they were used on combine engines in the late thirties.
    This one does not have a serial # and does not look like it has seen daylight in many moons.
    I am also looking for a source for the red cloth covered ignition wires and would like to have an extra cap/rotor/points.
    Thanks!
  13. That is what I have heard too...probably from the same post.
  14. lonewolf52
    lonewolf52
    Hi guys,
    After searching to no avail, I've got another basic Model A question...
    Does anything hold in the camshaft? I tried to tap it out (with the timing gear still on), but it only moved about 1/8". I don't see anything holding it in, but thought it wise to check here before I continue.
    Thanks
  15. Crazydaddyo
    Crazydaddyo
    Have you removed the valves, valve springs, and tappets?
  16. lonewolf52
    lonewolf52
    I have.
  17. Hey CrazydaddyO
    What's that bad ass motor going in?
    You've been avoiding that question!!!:)
  18. Crazydaddyo
    Crazydaddyo
    how about the oil pump / distributor drive?
  19. Crazydaddyo
    Crazydaddyo
    Your right I have been avoiding it. I was told not to.
  20. RussTee
    RussTee
    haha Tease!!!!
  21. Bluto
    Bluto
    OK I know....... He's putting it in a 1957 Nomad
    Don't tell anyone :)
  22. Crazydaddyo
    Crazydaddyo
    You didn't hear it from me.
  23. YUMMY!!!!!!!!!!!!!!!
    Wouldn't it be fun to show up to a "Tour" with that?
    Bad ASS Man!!!!!!!!!!
    Just Bad ASS!!!!!!!!!!!
    Is this your foul weather car? and the roadster for sunny days?
  24. That's a real nice pickup up and thats a really cool engine
  25. RussTee
    RussTee
    Very very nice Dan is dad happy as well? It should give no troubles now.
    Rusty
  26. Jiminy
    Jiminy
    WOW! That really is something else! Would really like to hear some particulars about the engine and carbs. From an unnamed source perhaps ;)
  27. Juggler
    Juggler
  28. I just found this month's thread! Guess my head's getting too big for my helmet, eh?
    CDO that is one COOL engine. If it's dyno'd, let us know what is does.
  29. Kinda a sad scene after CDO's post but here is my poor man's hop up kit:)
    B model Zenith and an F3 B head.
    The head is going to get the slow as molasses derusting hopefully starting this weekend. I had the carb on my car but wasn't happy with it. It ran WAY to rich. What should I have expected? It was a cheap swap meet score.
  30. Magnus B
    Magnus B
    Hey Bangers
    I have not done anything new to my banger just drivven it. Went down to Germany, about 400 miles one way, and raced on an old airstrip. It was a 1/8 mile dragrace on concrete. I don't know what times you guys run but I managed to get a 9.96 ET. No trap speed recorded, but my speedometer said about 70mph. To be honest it was flag started and hand times the old school way. But I'm pretty happy. That was with my coupe, model B transmission, stock model A rearend and 7.50-16 Firestone bias ply.
    I don't know if 9.96 is good, bad or ugly, but I won my class and I'm happy for it. It made the 800 miles roundtrip with no major troubles, just needed gas, oil, water and an occasional retightening of the magneto.
    It was really fun to race and now I kind of regret that I built such a mild engine. Next one will be bad I promise.
    //Magnus
