Projects 41 plymouth coupe 392 hemi build thread
Discussion in 'The Hokey Ass Message Board' started by farmer12, Apr 7, 2010.
  1. farmer12
    farmer12
    Here's a better shot.
  2. farmer12
    farmer12
    Yes I did remove it. I figured that it would only create a place where dirt can settle, water and eventually rust. It also looks cleaner now. I did get the tag off in one piece and is now hanging around my neck.:D:D:D
  3. Hogman
    Hogman
    from Dallas, TX
    I have been following this thread for a while and I must say you're building one of the best customs on the planet! Great to see some color at last. Hope to see this car in real life when it's finished. AWESOME.
  4. speed v8
    speed v8
    Coming along nicely! Can't wait to see this custom finished.
  5. farmer12
    farmer12
    I had a spare few hours this morning, so it was time to take the engine and gearbox out of the chassis. With a borrowed little crane, I got it all set up and called my son for a little assistance. (it was time for him to get up anyway:D) As I increased the tension, it all went smoothly for the first 20 inches until it suddenly dropped 2 inches. After a small heart attack, I realised that one of the ropes had tightened a little further around one of the engine mounts. Luckily no damage whatsoever, just scary. The rest of the operation went smoothly. Re-installed the chrome intakes and gave the engine a quick clean.
  6. OahuEli
    OahuEli
    from Hawaii
    Man that engine and tranny combination is purty!
  7. farmer12
    farmer12
    Thank you for the kind words gentlemen, it is appreciated. More progress early next week.
  8. n847
    n847
    Man I threw up in my mouth a little just reading about pulling that engine! Looking good as usual! This is the best part of the build!
  9. farmer12
    farmer12
    Dismantled all the stuff on the chassis and mounted the steering support. Had to lightly grind the bottom of the left engine mount in order to create a little more clearance. Perfect. :D More chassis work tomorrow.
  10. Ford blue blood
    Ford blue blood
    I believe you should move the support bearing as close to the center joint as you can. In it's current location the center joint will want to bind under load. Works really good and smooth now but load that bad boy up with the engine and body and it will feel "lumpy" and bind up.
  11. farmer12
    farmer12
    Thanks for the advise! I did try to move it in closer, but then the angles were all wrong, in combination with the header clearance. For now it behaves fine, and like you said, under pressure it may be different. Should it bind up during the first few test runs, I can add a second one behind the 2nd and 3rd joints. Thank you for thinking along!
  12. Plung
    Plung
    from San Diego
    Great progress, nice to finally see some color on the rear axle. Following this thread closely!
  13. farmer12
    farmer12
    Been doing a lot of chassis work the last couple of days. To start, I've cut out one of the cross members as it wasn't square with the rest of the chassis. Just finished welding it back in place again. Next was the front member. It is just too heavy and didn't give me the required clearance with the lower radiator valance. A round one is now in place, lighter and better looking. Then it was the front airbag clearance. With only one mm before it hit the chassis, a circular piece is now welded in, giving it 10-12mm of clearance. Much better!
    A big thanks to my buddy Jaap who came over this morning for a helping hand. Final welding and clean up on monday. And then, it's off to the sandblaster! Finally!:D:D:D
    hemi v8 likes this.
  14. farmer12
    farmer12
    Thanks Mick!
  15. OahuEli
    OahuEli
    from Hawaii
    I thought that front crossmember looked pretty heavy, (it might make a good battering ram :rolleyes:). No doubt the round one will be an improvement. Its good to see that you're able to fine tune the frame and chassis before it goes to paint. I hate having to go back and disturb brand new paint because of something that I overlooked and wasn't just right.
  16. farmer12
    farmer12
    Thanks OahuEli. The round cross member is about 4-5 kg's lighter, so that's an added bonus as well. Even though you try to think of everything before paint, I'm sure I'll be drilling a hole or two somewhere afterwards. It's perhaps inevitable, but I think the trick is to try and keep it down to a minimum.
  17. Finnrodder
    Finnrodder
    from Finland
    Nice progress again,Eric!
    I guess you'll have a roller pretty soon..
  18. farmer12
    farmer12
    Thanks Antti! A roller by the end of september for sure!
  19. farmer12
    farmer12
    After another morning of welding and grinding, the chassis is finished! Loaded it on the back of Jaap's truck and dropped it off at the sandblaster. Yes.:D
  20. Bart 56
    Bart 56
    Nice
  21. farmer12
    farmer12
    Thank you my friend!
  22. zibo
    zibo
    from dago ca
    Funny how there are so many steps to putting these things together.
    Good that you are willing to take yours apart and do it right.
    That engine slip is definitely a heart skipper!
    TP
  23. farmer12
    farmer12
    You're right Zibo. The amount of steps can be overwhelming at times. But at a certain point during the build, I realized that by taking it one step at a time, it all becomes logical. Take your time, think and build. Don't focus on all the things that still need to be done, just focus on that what you're doing at that present moment. Seems to work for me. Oh yeah, and being patient helps too.
  24. Finnrodder
    Finnrodder
    from Finland
    Are you going to powdercoat the frame?
    If thats the plan,dont forget to cover the the threads on the frame with bolts..
  25. Jimmy Tee
    Jimmy Tee
    Looking real good. I echo the advice above. Cover any threads with Bolts if your Powdercoating.
  26. zibo
    zibo
    from dago ca
    That is exactly right!
    There are times when I realize what I need to do (and have already done)
    and have one of those holey chit moments!
    Sometimes that makes it hard to figure out what project to start that day.
    If I'm in that state I'll start cleaning the garage a bit,
    which helps organize my head a bit,
    then finally I'm ready to tackle whatever it is.
    Yeah it takes a nutcase to do this stuff sometimes!
    TP
  27. farmer12
    farmer12
    Thanks guys. What you're saying is correct. BUT, it will be completely be zinc coated inside and out, before the double powder coating is applied. Meaning that I will need re-thread all the holes, taking off the powder coat layer while the zinc coating should primarily remain in place. The company performing the work have assured me that this minimalizes the chance of rust appearing it's ugly head ever again.
  28. metalguy
    metalguy
    from down south
    Nice work on the chassis. Must be good to finally see some color in a few weeks. So the chassis will be dropped in a zinc bath? Looking forward to see how it turns out. Great work as usual!
  29. Finnrodder
    Finnrodder
    from Finland
    Just remembered that a friend of mine used the same zinc/powdercoat method on the balcony support poles.The coater said that your kids wont see any rust spots on them,but its possible that your grankids will see.Time will show was he bullshitting or not,but it sounds really reasonable way to coat stuff like that.
  30. farmer12
    farmer12
    Thank you metalguy. The whole process goes as follows: First to the sand blaster, then it will be dropped in an acid bath, then into water and then into a zinc bath. Which by the way these baths are 12 meters long by 3 meters wide. Don't know the depth, but it's deep. The zinc bath is heated 24/7 at high temperatures. Zinc will also go inside all of the chassis, that's the reason I've drilled so many holes. (for air and acid/water/zinc to escape.) After the zinc is dry, the chassis will be prepared for the double powder coating. The whole process will take about 3 weeks before it's completely done and ready to be picked up. Can't wait!:D:D:D
