Mid 50's mopar experts Mopar experts
Discussion in 'The Hokey Ass Message Board' started by Streight8, Jun 30, 2013.
  1. Streight8
    Streight8
    Anyone know if a 53/54 Plymouth frame will interchange with a 55/56?
    Wheel base is 1 inch longer in 55 and the pedals come up from frame but other than that? Thanks
    If someone has a shop manual for 53/54 with the frame dimensions they could scan that would be great.
  2. 35desoto
    35desoto
    The top mounting bolt pattern for the upper suspension arm is different in a 55/56 than what it is in an a 54 and earlier chassis
  3. Streight8
    Streight8
    Do you know if the body mount positions and chassis the same from the firewall back?
  4. 35desoto
    35desoto
    I have a 55/56 workshop manual but nothing in the 53.54 range to make the comparison. I know that using the older style upper suspension arm set up is not much different in ride or geometry than the later one - why did they changed it? who knows!
  5. Streight8
    Streight8
    I found a of frame dimensions in a post, it looks like it is fairly similar firewall back but 53,54 very narrow through front frame rails the 34 on 56 as opposed to 31 but width on first two body mounts are the same at 48 and 51. However I think it is going to be too narrow. Pity because there is a fellow selling a complete 54 frame all rebuilt right down to new tires for $100 yes one hundred dollars Canadian.
  6. Rusty O'Toole
    Rusty O'Toole
    They are completely different cars with different frames.
  7. plodge55aqua
    plodge55aqua
    from Alberta
    Found you a frame If you want it.. sported a v8 too... :)
  8. Streight8
    Streight8
    on the phone with him now!
