Where do the wires go on a Sun Super Tach II?
Discussion in 'The Hokey Ass Message Board' started by 50dodge4x4, Jul 27, 2006.
  1. 50dodge4x4
    50dodge4x4
    Well, I went out and dropped big bucks :rolleyes: ($5) on a Sun Super Tach II from a guy I know. He had it in his truck for a while, but took it out a few months ago. He doesn't remember where the wires are suppose to go.
    There is a black wire with a soderless eye on it, a white wire that has about 1/2" stripped back, a green wire and a red wire, both of which look like they were never used.
    I presume the black wire connects to the neg side of the coil and the white wire is a ground wire. I figured the green and red wires were probably for the light? Thought I should check before I hooked it up wrong and smoked the thing, I've done things like that before....
    Gene
  2. Barn-core
    Barn-core
    Black - ground
    Red - switched +12V
    Green - negative side of coil
    White - panel lights
    This is directly off of the tach install instructions, from the one I put in my car a few weeks ago. Good luck.
  3. mercury Bill
    mercury Bill
    Yep, thats it 100% correct
  4. 50dodge4x4
    50dodge4x4
    WOW! Good thing I checked, would of been smoke for sure.
    Thanks,
    Gene
    Nitro Pontiac likes this.
  5. carfreak101
    carfreak101
    from warren
    thank u barn core i have to put it in my car immediatlly
  6. wallygt
    wallygt
    from canada
    where can i get the wiring haress for a sun super tach II
  7. Toner283
    Toner283
    :confused::confused:
    There should be 4 colored wires coming out of the back of the tach. add extra length to all of them as needed and hook them up as listed in Barn-core's post. Tach's don't usually come with a harness. Just a few inches of wire that you need to splice to.
  8. racer32
    racer32
    The Sun Super Tach that I have(had??? can't seem to remember where I put it) uses little round connectors that plugged onto pins on the back...anyone know where to get those connectors??? Sorry for the hijack!
  9. James Kilby
    James Kilby
    from maryland
    I have an older tach. 10 years or more. Found it in a old box. No instructions. I want to install it but my colors are black, red , blue and green. Do we think the blue the same as the white?
  10. 1ton
    1ton
    Got my super tach II sitting here and my wires are red black green and blue. No white. I thought that the blue was for the light.
  11. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
  12. All these wiring questions can usually be solved by pulling the can, a diagragm is usually pasted on the innards.
  13. sixty-fouronthefloor
    from Wyoming
    This is very interesting to me as I have a sun super tach II, however mine has five wires. Anyone have any idea what's going on there?
  14. best2923
    best2923
    from north Id
    see post #2 100% right
  15. Lee_Ford
    Lee_Ford
    I also have a Sun Super Tach II and needed the pinout IDs. Found this on another forum. It was for model 7901 and mine is a 9109. Logic says it is the same. I hope so. Goin' to try it next nice day.
    B is for B+ battery
    G is for ground
    L is for light
    T is for the ignition [ or trigger might be a better name. ]
      33.1 KB
    MUNCIE likes this.
