ive got a 4 ft box/pan brake, but i dont have the counter weights to help with the bending. my question is: how much do those weights usually weigh?? i can make my own, or if someone knows where to get them..maybe id buy them. thanks.
The one on my brake is a cast iron slug about 8 inches long and around 3-4 inches in diameter. It's mounted at the end of a 2 foot bar. You could probably accomplish a similar effect by slipping a longer piece of pipe over the grab bar on the bottom to give you a little more leverage.
