Hot Rods >> post war '30 roadster build <<
Discussion in 'The Hokey Ass Message Board' started by Kiwifruit, Aug 9, 2012.
  1. 48fordnut
    48fordnut
    The build and body look good. I have a riley auto parts double z frame under mine. I'll try and get some build pics soon. have painted the frame and starting to put it back together
  2. TexasSpeed
    TexasSpeed
    from Texas
    This is going to be a fun AV8 to watch. Subscribed.
  3. Kiwifruit
    Kiwifruit
    sorry for the lack of updates, I have been making some progress. Driveshaft/torque tube are shortened & installed, steering is mocked up & i'm just juggling around with the pedals/steering column position/gearbox linkage before I bolt it all in.
    Will take some pics this week & post up.
  4. Great start. Will be waiting for those pics.
  5. Kiwifruit
    Kiwifruit
  6. Kiwifruit
    Kiwifruit
  7. They arent showing for me.
  8. Kiwifruit
    Kiwifruit
  9. Kiwifruit
    Kiwifruit
  10. Carter
    Carter
    Looking good in the pictures. Glad to see an update.
    Sent from my DROID device using the TJJ mobile app
  11. Hot rod porn right there :D
  12. Atwater Mike
    Atwater Mike
    Kiwi, I must admit I was taken aback when I saw the '46 sideshift tranny...(of COURSE it shifts from the right!)...but I never thought about it! Just seen floorshifts down under.
    Yes, your list has all the right stuff. Pedals look correct, just need a little massaging.
    Still...So neat to see a roadster with a column shift! Can't get over it... LOL
    The body is gorgeous. '30s are so...GEAR! Carry on, Mate.
  13. Rickybop
    Rickybop
    Keep it up, KF. Looks good. God, I love traditional roadsters.
  14. Kiwifruit
    Kiwifruit
    thanks Guys, Atwater Mike, I have 3 different types of pedals, 40's Truck, 40's Pickup & 46-48 Passenger, just trying to work out which is going to work out best.
  15. pug man
    pug man
    from louisiana
    Man what a breath of fresh air to see a build like this. Doing a great job bloke, keep it up.....
  16. Kiwifruit
    Kiwifruit
    Here is a pic of the front, B4Baz & I reversed the spring with his press, making sure to keep the same arc. Spring is now a bit wide & the shackles are pointing down.
    Guess I will pull it out & put a bit more arc in it?
  17. brady1929
    brady1929
  18. kingpins
    kingpins
    awesome build!!!
  19. Kiwifruit
    Kiwifruit
    Should have been finishing off my steering but got distracted by my headlight bar, Henry loves the camera, but isn't much help...
    cully33 likes this.
  20. Kiwifruit
    Kiwifruit
    Steering box is clamped in while I finalise placement. I'm using an F1 box & a VW Kombi mount, not quite traditional but looks the part & solves the clearance problems with the Starter being right hand drive.
  21. Kiwifruit
    Kiwifruit
  22. Kiwifruit
    Kiwifruit
    Also I found a windshield frame, just working out how much to chop it
  23. So-Cal Speed Sacramento
    Alliance Vendor
    from Sacramento
    the stance is right on. i'm glad to see an undropped axle without a suicide front end!!
  24. Kiwifruit
    Kiwifruit
    yeah I like the look, I think it is correct for a 40's build, If you look through the old pics from that time there were tons of guys running undropped axles. Also just running a Model T spring in the rear with no step in the frame.
  25. It looks sooooooo good!!!!
  26. OLLIN
    OLLIN
    awesome build Kiwi.
    if you get a chance can you post a pic of the finished wishbone ball mount? thanks!
  27. Kiwifruit
    Kiwifruit
    will do Ollin...as soon as its finished haha.
  28. Going to be a cool car!
  29. midroad
    midroad
    What exhaust manifolds are you going to use? I want to build a similar car from a '29 model and have been trying to work out cross steer using a '46 box but can't fit any headers. I think you have solved my problem. Thanks, Mike.
  30. Kiwifruit
    Kiwifruit
    Hi Midroad, I will be doing my own headers with stainless flextube (see pics), stock exhaust manifolds don't fit with this setup.
