Wheel / Tire size on back of 64 Galaxie
Discussion in 'The Hokey Ass Message Board' started by gearhead78, Apr 30, 2013.
  1. gearhead78
    gearhead78
    from Dallas TX
    I have the front on the way and was about to order the rears. Anyone know if a 15 x 8.5 3.75" backspace Torq Thrust D on the back with a 275-60-15 fits? Doing some quick measuring it looks like it will but wondering if anyone has used that size without issue before I place my order.
  2. EXracer64
    EXracer64
    from nj
    I've used that setup but an 8" rim and it did clear but close to the 1/4. Go for a 8" rim or 4" bs.
  3. bald_and_grumpy
    bald_and_grumpy
    I fit that size with 8" torque thrusts under my 64, but I had to trim the fender lip down to keep it from scraping.
  4. gearhead78
    gearhead78
    from Dallas TX
    Crap. They only make that wheel in 8.5" with 3.75 might have to step down to a 255-60
  5. gearhead78
    gearhead78
    from Dallas TX
    Looks like I may be able to skate by. I found this car on line and he lists 275-60 on the rear. This is the exact look I am after.
    treb11 and shortypu like this.
  6. Heo2
    Heo2
    I had those rims with 275 60 and with 2 or more
    in the rearseat it toushed somewere high up in
    the wheelhouse. Now i have 255 75 and they are
    fine but a bitch to get of and put on the car
  7. gearhead78
    gearhead78
    from Dallas TX
    I used to stuggle with getting big tires under a 64 Elcamino until someone showed me a trick. You jack the car up high and tilt the wheel face down under the drum. Pick the tire up with the hub down inside the wheel and rotate up in to place. Its hard to describe without seeing but it works great.
  8. jpnewlin
    jpnewlin
    I have to drop the axle to get mine on and off. As long as you know what your limitations are you should be fine. Sometimes it just is not worth it though.
  9. EXracer64
    EXracer64
    from nj
    Yea I had to back off the shock bolts to get the rear lower to fit the 275 on. A 255 would work.
  10. Drive Em
    Drive Em
    275-60 is to squatty and does not look that good. A 255-70 is just the ticket and will fit on on the back of a '64 with an 8" wheel.
  11. gearhead78
    gearhead78
    from Dallas TX
    Its a convertible if it makes a difference. I thought about a 255-70 at first but thought the 29.1" might be too tall compared to the 28" 275-60
  12. Drive Em
    Drive Em
    They are not actually 29.1" tall, more like 28.75". I have used them in alot of other applications and they always look better than the 275-60.
  13. gearhead78
    gearhead78
    from Dallas TX
    Thanks for the tip. I may try that. Would you do a 225-70 front on the 7" ?
  14. FlatTracker
    FlatTracker
    from Ohio
    the 225-70 or 215-70 a 7in should work.
  15. gearhead78
    gearhead78
    from Dallas TX
    managed to get the 20" truck wheels off tonight getting ready for the new combo. Found a quick easy way to get them out from under the 1/4's. I was able to place a small bottle jack between the spring and the frame to raise the body far enough off the frame to snake it right out.
  16. gearhead78
    gearhead78
    from Dallas TX
    Took a couple days to sell the other wheels and got the new Torq Trusts and tires 225-70-15 and 255-70-15
    Its the exact look I was after and looks killer on the car but its just too close on the outer wheel houses in the rear. I now have this set up for sale and 5 spoke Hailibrands on order. I wish I had seen the Halibrands first because they make multiple backspace and are running a special so they are not a whole lot more than the TTD's were.
  17. Where are you getting the Halibrands from?
  18. gearhead78
    gearhead78
    from Dallas TX
  19. That's weird, the last time I called him the phone was disconnected.
  20. gearhead78
    gearhead78
    from Dallas TX
    I had to call a few times but did get ahold of him. He sais he is having trouble with his voicemail system.
  21. gearhead78
    gearhead78
    from Dallas TX
    What ever I can get done Sunday is going to make or break my plans to take this car on Hotrod Power Tour next weekend. I can't use the excuse for no wheels because Halibrand came through with their promise and got me my "new" new wheels today. I am very happy with the quality. They are going to look sweet.
  22. 390Merc
    390Merc
    from Indiana
    Not sure about the backspacing on my wheels, but here are a couple shots of mine with two different sets of 8" wheel/tire combos on the rear. They fit really nice. Both sets are 275/60-15 on the rear.
    shortypu likes this.
  23. speedyb
    speedyb
    from socal
    Those Halibrand's look great.
  24. 390Merc, Your black Galaxie when equipped with the steel wheels and small caps is absolutely stunning!....................Don.
  25. gearhead78
    gearhead78
    from Dallas TX
    Agreed. I like it both ways. I have soft spot for slots. Very nice car.
  26. gearhead78
    gearhead78
    from Dallas TX
    Halibrands installed 042913forsale 148.jpg 042913forsale 149.jpg 042913forsale 150.jpg
  27. brooksinc1976
    brooksinc1976
    from P-Town
    Looks great. I just got a 64 and hate the rims. Did you lower the front or is that stock?
  28. Ahhhh... you fell for a 10 year old thread... :D:D:D
    lothiandon1940 and Moriarity like this.
  29. Moriarity
    Moriarity
    SUPER MODERATOR
    Yup, and the OP has not been here since 2021....
    bobss396 and lothiandon1940 like this.
