Features Kinmont Brakes
Discussion in 'Traditional Hot Rods' started by flt-blk, Oct 22, 2003.
  1. I have been hearing a lot about these latley but don't understand what they are.
    I understand them to be old school disk brakes, but why are they so special.
    Does anyone have a picture, google didn't turn up anything.
    Thanks
    TZ
  2. hammeredabone
    hammeredabone
    Honest might shed some light on this but Bob Wilson is suppossed to be setting up to reproduce these. Looking at his other products, it should be a winner!
  3. I was talking to Honest about this last night, problem is I can't picture what they look like.
    I guess I need to stop by Bob's shop and see if he will let me peek around.
    TZ
  4. Jive-Bomber
    Jive-Bomber
    MODERATOR
    I found a thread on the old ford barn about Kinmont info:
    Bill,
    You need to get a copy of "The Rodders Journal", No.7 for a very comprehensive article on Kinmonts. Also see Rod & Custom Nov.'73.
    As a side note let me tell a story about the big one that "got away." About 30 years ago I went to a swap meet sponsored by the MTRC. BIG swap, and back then it was really good. Anyway,inside a building at the fair grounds was a husband & wife selling home made jelly, quilts and nick-nacks. Junk- at least to me. Well what I didn't see were the NOS Kinmonts in a cardboard box. Never installed, complete, and with all paper work.
    A fellow by the name of Dennis B-----(name withheld to protect the innocent)from Elgin,IL saw 'em and paid the $200 asking price. Iv'e often wondered what happened to them.
    Did I learn anything that September day? You betcha!
  5. Elrod
    Elrod
    I just found on Google that Kinmont brakes were to be standard on all production Tucker automobiles.
    Now, all you gotta do is go to the junkyard, find a Tucker, and you are set!
  6. here is what they look like,sorry for the poor picture. i've talked to two guys that had them on their cars and both said they didn't work very well and were hard to adjust. hope Wilson correects the problem
  7. Jive-B
    I read that thread too,
    Thanks for the pic. Is it actually a disc brake inside the housing, or is it a modified drum?
    Does it use a wheel cylinder or a caliper?
    TZ
  8. DrJ
    DrJ
    To put it very simply, it looks and works more like a standard transmission clutch than the disc brakes you are used to.
  9. modernbeat
    modernbeat
    from Dallas, TX
    Tyler, the fact that Kinmonts are disc brakes is a misnomer. They are actually closer to a drum brake at 90 degrees to what we normally understand as a drum brake.
    The easiest way to describe the Kinmont action is to think of it as a clutch presure plate and a clutch disc. The pressure plate (and flywheel) are fixed to the backing plate and the clutch disc is attached to the hub. The wheel cylinder instead of pointing forward and backward like a standard cylinder, points out parallel to the spindle. The cylinder activates a fork that puts pressure on the clutch disc.
    According to TRJ, the brakes are unique to the corner of the car they are on. Left Front, Right Front, Left Rear, and Right Rear are each unique.
    As of today I don't know if Bob is making a Kinmont facimilie that uses regular drum brake parts, or a real Kinmont replica that can mix and match with real Kinmont parts. I suspect he's making them like real Kinmonts though.
  10. Honest
    Honest
    from Dallas Tx
    Just like the originals...down to the little numbers cast in the back.
  11. DrJ
    DrJ
    [ QUOTE ]
    [/ QUOTE ]
    Anything short of "as original" wouldn't be worth spending the time on....
    I want sum.
  12. TV
    TV
    YEP<YEP<YEP<...TV [​IMG]
  13. Honest
    Honest
    from Dallas Tx
    Bob is even casting the wheel cylinders...and as I understand it..they will appear on the outside just as original...but,...he is using internals (spring and plunger etc..} that can be had at any good parts store. So..a guy can rebuild the cylinders with availiable parts.
    Thats a good thing in my opinion
  14. tommy
    tommy
    About 10 years ago there was a completely restored set at Hershey...$2500.00 The blue Deuce coupe on the Beach Boys Album has a chromed set on it.
  15. Honest
    Honest
    from Dallas Tx
    The molds were taken to the foundry today.
    The original brake cylinders have a one inch bore...Bobs will have one an one eighth inch bore. He is also using a softer brake pad lining than the original. Both for improved stop power. He also said they are very easy to adjust.
    Bob recommends checking out Rodders Journal #7 and the Jan 1949 Hot Rod Magazine for great photos and information on the Kinmonts.
    The Beach Boys car {the brakes anyway} played a major part in the developmet of Bobs finned aluminum backing plates...ala the "Kinmont good looks" tag in his ads.
    Three years of planning, discussing and cussing later....the real deal is in the works.
    Can you tell im stoked? B?]>
  16. burger
    burger
    I saw ONE at Hershey this year. Asking price was $1000. Supposedly previously owned by Robert Kennedy.
    Ed
  17. gmans356
    gmans356
    from MDR
    There was a guy at the Roadster show last month that had replicas, around 2 grand for unpolished and they look great with disc's underneath. once I find his card I will put it up.
  18. Harms Way
    Harms Way
    Here ya' go...
  19. el Scotto
    el Scotto
    from Tracy, CA
    10 year old post. :rolleyes:
  20. Harms Way
    Harms Way
    Just my point ! it took that long for somebody to post pictures for this poor guy ! :cool:
    (Thank goodness somebody else brought it up today before I responded to it !:eek: )
  21. Probably never find any anyway...
  22. Ole don
    Ole don
    They were used on Chrysler and DeSoto big cars, taxi's and airport limo's. They are pictured in old Motors Manuals.
  23. donut29
    donut29
    from canton MI
    Those were different
  24. 55willys
    55willys
    The ones on Chrysler and Desoto were different than Kinmonts. The Kinmonts as explaned earlier work like a clutch. The backing plate would be like the flywheel but it is fixed to the spindle. The disk has teeth that engage the outer hub drum. and the pressure plate is actuated by the wheel cylinder via the horse shoe pivot.
    Chrysler had a wheel cylinder that rotates the inner pads, as they are rotated they ramp up on ball bearings in tapered slots causing the pads (which are full circle) to expand sideways and contact the flat face of the 2 piece hub. These brakes are the only self energizing disks that I know of. Their downfall was the number of balls was too few causing high wear on the balls and slots. They were self energizing and worked too well to the point of being touchy and grabby.
  25. summersshow
    summersshow
    from NC
    So... Ten years later... Did they ever get remade?
  26. alchemy
    alchemy
    Not yet.
  27. Glad someone finally answered my question, I have been waiting.
  28. DirtyJoe
    DirtyJoe
    There is a set in the classifieds.
  29. Dar73
    Dar73
    Johnsons Hot rod shop is remaking them..... I am not that familiar with the originals and do not know how close they are to them but if you like Kinmonts, here ya go:
    johnsonshotrodshop.com
    (256) 492-5989
    Good luck- there was a thread about there repo's too
  30. need louvers ?
    need louvers ?
    Nah, the Johnson's version is kinda like So-Cal's Buick drum kit. It's a cover for a disc brake inside. I saw them at the GNRS and although they are kinda semi-cool for a fake, I could tell they were fakes from about 60' away.
