I'm at the stage of building my brake pedal assembly for my 28 chrysler coupe, I need a non power disc drum master, I can't remember what will work. Under the floor set up, using a 28 plymouth pedal, ratio is about 8 to 1, I believe I used an early eighties gm pickup master in my T but that was twenty years ago. I'm sure the lines can come out either side, no issues there. Can anyone here recommend a master cylinder that works for them? I want to use a production item, I live in a little town in British Columbia, I want to be able to source the parts locally. Thanks.
71 econoline disk/drum http://www.ebay.com/itm/10-1647-Car...ar:1971|Make:Ford&hash=item3ccee6685b&vxp=mtr even includes a new pushrod
Ford parts on my chrysler? Sacriledge! Thanks, I'll check tomorrow at my parts store. Anyone else care to chime in? I could use some more ideas, else, ford parts it is. See it at www.trolls.quack.net Thanks pinto joe, and jrblack.
We always used Camaro and Mustang M/cyls but I'd bet if you look around at the Darts and such you can find a non power Chrysler disc/drum M/cyl that will work just fine. I used every factory brake part from a 71 Camaro for my first 34 Ford P/U... Calipers, rear end, M/cyl, distribution block etc. Only the location and brake lines were changed. It has always worked for me.
Orderd a new master, its $43, here, not rebuilt, early 80's chev full size pickup, 1 inch bore, deep piston hole for pushrod, thanks to all of you for the info.
Sacrilege ? Ok, I'm guilty, for using a Corvette m/cyl for my 40 Ford........ We won't tell, if you do use a Ford item......... 4TTRUK
