37 dodge
Discussion in 'The Hokey Ass Message Board' started by kmiele, Jan 12, 2013.
  1. kmiele
    kmiele
    i switched over a 1937 dodge to 12 volt but want to try and use original fuel gauge can this be done and how
  2. Rusty O'Toole
    Rusty O'Toole
    Use a Runtz voltage reducer, or a center tap on the battery, or a resistor, all will give you 6 volts for your gauge and other 6 volt accessories.
  3. kmiele
    kmiele
    I got a resistor but in the directions it says i need to know the ohms range of my gauge? Depending on the range i may have to use more than one resistor?
  4. Just search for the exact P/N, but there is an integrated circuit voltage regulator that cuts volts form 12 to 6 output. I am going from memory, LM7806 or similar to that. Only a couple dollars, good for 1 amp which is plenty for fuel gage.
    Put one on my 37 Chevy fuel gage and works just like it should, the car is 12 volt conversion.
  5. kmiele
    kmiele
  6. flathead41ford
    flathead41ford
    from Mentor OH
    What about an instrument cluster voltage reducer that ford ran? Ford used 6 volt gauges from 1957 through the 70s. I'm using one from MACS in my 55 to run my fuel and temp gauges. From what I read, if a runts fails it will send 12 volts to whatever they are supplying. Ford reducer will fail to open and allow 0 volts through. That is what I read, not experienced.
  7. notaford1
    notaford1
    from webster ny
    If it helps Standard Ignition part # RU100
  8. kmiele
    kmiele
    thanks for all the info guys, i will put somethin together.
