FED cockpit pics?
Discussion in 'The Hokey Ass Message Board' started by Blindmule, Jan 7, 2013.
  1. Blindmule
    Blindmule
    from Bama
    Anybody have any pics of the drivers compartment need some ideas to put my junk mostly the shifter:eek:
    Thanks;)
  2. D_Lazaris
    D_Lazaris
    from So. Cal
    Our 1958 Chassis Research flathead dragster.
  3. Subscribing to this one...should be interesting. Come on guys!
  4. hrm2k
    hrm2k
    here are some detail shots of Roland Leong's 1964 HAWAIIAN dragster
    The trans is a 39 Cad / LaSalle 3 speed box using second and third gear only
    Gear shift lever.....all the way in....second gear.....all the way ....high gear
    There is a thread from 2011 called One More For Frank Morawski with a lot more shots..............hope this helps
  5. 60srailjob
    60srailjob
    from nowhere
    here's a few maybe they'll help....
  6. jw_deuce
    jw_deuce
    from Central OH
    Here is an old picture of my dragster, kinda hard to see details but this is the best shot I have of the cockpit
  7. coupemerc
    coupemerc
    Here's mine. Shifter is the knob to the right of the filler cap.
  8. 296 V8
    296 V8
    from Nor~Cal
    Sorry but this ones got to be here :D
  9. 1968FED
    1968FED
    from Goddard KS
    Here,s mine mid-sixties Jim Davis chassis running powerglide and SBC.
  10. dreracecar
    dreracecar
    from so-cal
    Cars in the trailer right now but I have a B&M rachet mounted to the tailshaft and a link rod to a handle mounted to the rear end housing and a push rod to the reverse lock out. Its 1 hand opperational and the shift handle always returns to the same spot on both upshift and downshift and can never shift from low to neutral unless you start in high gear to begin with.
  11. travisfromkansas
    travisfromkansas
    I have more I'm sure but that's all I can remember off the top of my head.
  12. Do a search for Butterfly steering wheel picture thread and you will find many pages of pics of dragster cockpits.
  13. Henry's NHRA approved welded aluminum can, C-T gas pedal,
    Fuller butterfly steering wheel lacking the wood grips all this within
    the frame rails created by Jim Keeter and Dad back in late '63
  14. THAT sir, was some sexy shit!
  15. Here's a few of our ELTA Club track ride....an old 1969 Don Long chassis 200" injected sbc rail.
  16. If you are looking for a place to put your junk in a FED, most of them require you to rest it on the differential!
  17. Bull
    Bull
  18. Blindmule
    Blindmule
    from Bama
    I guess you say put your junk on the chunk:D
  19. hrm2k
    hrm2k
    Yes you do :eek:
