Hey guys, pretty much got all my sheet metal back on my 28 Tudor. I really wish the front was another inch lower. Here is my set up. 36 axle dropped my 296V8, reverse eyed 2" drop Posie spring. Running 145/15's as well. I was thinking of flattening the front crossmember to gain that 1". I'd like for the tire to be in the fender just a little more.
I plan to do the same to my A crossmember too. '34 axle dropped 4", reversed eyes, but nothing else. That sucker is gonna come down whether it takes me a day or 5. Slice away!!
I've had the radiator and hood on as well. How much travel should it have. I don't want to be knocking on the bottom of the frame, or would i have to notch that as well.
A 1" drop crossmember won't hit the frame. I was told that the 2" may require notching of the outer frame rails.
Has a small step on the frame like Tardell's with coil overs(cheated). A flattened crossmember is my only solution i believe. Looked for some threads and only found a couple. Still up in the air.
You need to be aware of the tires hitting the fenders when they are turned, my avatar tires rubbed on the fenders when they were turned. The width of the axle and fender clearance will come into play, they will rub on the fender at the back of the tire.
It'll come down more, don't panic. It takes a while to settle, how much you drop the axle? And, like another said, when you get low enough there is a different axle width for tire clearance inside the fender. I did the 2" posies on a '32 and it took a couple months to settle in.
You should have got a dropped axle or you can have yours dropped, i,d leave the x member alone. There bad about cracking anyway
+1, I'd be wanting to have it all together and drive it a bit first to see if it settles out some. It looks like you are still missing a few hundred pounds off the car that might bring it down a bit more.
A lot of guys don't care for the reverse eye mono spring,,personally I like them and it comes with shims that you can rearrange to drop the front lower. HRP
Another warning, the headlight bar bolts hit my tires, put carriage bolts in through the bottom with SS acorn nuts on top to keep it from gouging the tire in an autocross corner (or when doing doughnuts). You can always add a spacer when it's all together, it's much harder to flatten the crossmember later.
I took the top two leaves out of my Posies spring to get an extra inch with no problems with a rough ride or bottoming out. You might consider this before cutting the crossmember out. It's cheap and easy Along with the added weight of the finished car, the natural settling that occurs after being driven a little the removal of a leaf or two, you'll have it sitting lower without spending any money.
you can see how I did mine... page 3 I think. http://www.jalopyjournal.com/forum/showthread.php?t=530582&page=3 I did end up notching it and using a dropped axle...
