Hey guys, Has anyone used a '65 Mustang radiator that's $140 in a model A grill shell? I have a buddy building a '42 that's using a '36 truck grill shell with this radiator that fits pretty well. Better than buying the $800 one! Just curious if anyone has the dimensions on the '30-'31 Model A shell before I buy the radiator. Thanks
I have used the early Mustang type radiator in both the model "A" (chopped shell...) and the "T" shells quite easily... That's what I have in my "T's" Track nose... Just be sure to buy enough radiator to do the cooling job at hand... Several core thicknesses are out there ...
Fits in my 30-31 she'll ok, not the greatest look, but like you said it beats 800 dollars, cools a small block just fine...
it fit in my Chevy grill , had to bend the sheet metal flanges on the radiator near the bottom to clear Just a mock up in the picture, actually radiator sits lower in shell
Thank you Mink! That picture saved time and guessing on this sort of thing! That doesn't look that bad. I bet with an expanded metal grille blacked out it could be doable.
Look at the $200 aluminum ones on eGay.. Have one in my coupe and works great.. Will fit a 30/31 shell nicely.. At $200 if it lasts a few years I'll be happy...
Biggest beef is the shape of the upper tank...if that's not addressed, it'll look like one of those Model A clones where they just dropped a 'glass 'A' over a Pinto pan!
There is one in my roadster and it cools the 390 Caddy Engine---BUT mine is from a 6 cyl falcon,or comet----same rad,but bottom outlet is on Driver side and top outlet on pass side
There are plenty of aluminum model A style radiators available for around $150, so why use the mustang radiator?
I have one in my 1929 model A It,s a 1965 mustang 3 core it keeps my HO 302 cool at about 185 to 190 no problem
