Has anyone ever found or used a 3/16" inv seat x 1/4" inv. male 45 degree brake line fitting?? I am trying to clear a suspension part, and I have those speedway thru frame fittings that they sell, and I have stock 46 ford front brake likes, and I would like to set the lines at a 45 degree to clear my radius rod, but I cant find one anywhere or if anyone makes one, has anyone ever use or had one? its hard to describe, but this is the best I can do!
Sounds like you want a reducing 45. I've never seen one, you might have to use a regular 45 with an adapter.
Go to a tractor dealer that can make hoses like a CAT dealer they have hose and fitting books might be able to get what you need good luck.
I've seen a 45 with a pipe thread on one side, how about a 90 deg. It's kind of hokey but you could use a trailer tee and cap one port.
