I have a 1961 ford falcon with 38000 miles it was my Great Grandfathers its been stored most of its life and I am having a problem with blowing fuses on the brake tail light fuse. I traced the wires and they look perfect. I have headlights back up lights turn signals. the wires look perfect under dash. I replaced headlight switch hoping that was the problem but it wasnt. Any help would be appreciated.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Welcome to the HAMB post an intro.Beside what Shineyside said also pull the bulbs and see if the sockets are cruddy as it may be grounding out at the socket.
Same thing happened in a few of my early falcons.If you have a trailer plug then that is where the problem will be
