1934 Ford rearend swap
Discussion in 'The Hokey Ass Message Board' started by thirt4, Oct 1, 2012.
  1. thirt4
    thirt4
    from Arizona
    Today I spoke to a guy on the phone who is going to buy one of my spare gas tanks.
    During the conversation, he asked what rear end was under my '34 coupe. I told him it was at this time, the stock banjo rear end, unknown gear ratio but I have been told to exchange it for an 8 inch or a 9 inch Ford.
    He said on his '34 he has an Olds rear end that is too wide and does not know what to replace it with.
    Does anyone have a "perfect" non banjo or Olds rear end idea that we should go with for our cars? I sort of like the 8 or 9 inch idea but am not sure if that is the way to go and if it is, I do not know what gear ratio I should run.
    For my car, I will be using (I believe) the stock 3 speed transmission unless I find the "perfect" T5 5 or 6 speed to go behind my Merc that I have decided to attempt to put in it.
    Also, I do not want to change out the rear leaf spring combo from the stock setup. I like that mono leaf going across the back. (If it is possible to keep that setup)
    I do not know what his engine and transmission combo is yet but should tomorrow.
  2. fordcpe
    fordcpe
    My 34 has stock buggy spring front and rear with four bars with 8 inch rear 3.25 gear. You would have to get a open drive truck trans to use with 8 or 9 inch ford.My 8 inch hits the stock floor on big bumps once and awhile so the bigger 9 will hit the floor for sure.You don't need a 9 inch for a flathead anyway. The stock rear buggy spring makes it hard to run the exaust over the rear.Darrell
  3. Bigcheese327
    Bigcheese327
    Width wise I believe the Maverick 8" is ideal; or the '57 Ford or Early Bronco 9" if you need the strength.
  4. fordcpe
    fordcpe
    Mine is a 65 66 mustang 8 rear.
  5. I used a Bronco 9" on my 34. It fits perfect. Came with a 3.50 gear ratio. Speedway brackets. Modified the crossmember to take a straight ( as opposed to the curved 34' ) 40' rear spring. Works fine.
  6. fordcpe
    fordcpe
    Ford
    OutsideWidth Year Model
    56.50 1969-1977 Maverick 8"
    57.00 1974-1978 Mustang II 8"
    57.25 1957-1959 Ford, Ranchero, Station Wagon
    57.25 1965-1966 Mustang
    58.00 1966-1977 Bronco
    58.00 1964-1965 Falcon
    58.00 1977-1981 Granada/Versailles
    58.50 1977-1981 Versailles
    59.25 1967-1970 Mustang, Fairlane, Comet, Cougar
    60.00 1967 Cougar
    60.00 1958-1960 Edsel
    61.00 1964-1971 Ford Full Size
    61.00 1949-1951 Mercury
    61.25 1957-1972 Ford F-100 Pickup
    61.25 1960-1964 Ford Full Size
    61.25 1971-1973 Mustang
    61.25 1967-1973 Torino, Ranchero, Fairlane
    63.00 1970-1979 Ranchero & Torino
    63.00 1972-1979 Ford Full Size & Intermediate
    63.50 1967 Fairlane (Coil Springs)
    65.25 1973-1986 Ford F-150 Pickup
    65.25 1978-1986 Bronco
    65.25 1973-1986 Ford Van 3/4 Ton
    68.00 1972 Ford Van 3/4 Ton
    69.25 1977-1986 Ford E-150 Van
  7. ss34coupe
    ss34coupe
    I have a 57 Ford nine inch in my chopped coupe, with the stock spring. It has 3.5 gears, and 7 inch rims. Fits and works perfectly.
  8. smittythejunkman
    smittythejunkman
    I have a 57 ford 9 inch rear end in my 34 coupe, the width is right
  9. ss34coupe
    ss34coupe
    Here is the 57 Ford nine inch rearend in my 34 Ford coupe. Used the stock rear spring with one leaf taken out and flattened a bit. This setup has worked well for many years, and the ride is surprisingly good for a buggy spring suspension.
  10. Harms Way
    Harms Way
    I am a big fan of 9" Bronco Rear axles and have used them under a number of chassis,.. I also like the big bearings and 5-1/2" bolt circle. as well as the fact that a number of them come with 3:50 Trac-Lock Differentials. But with that said, A friend of mine used a Flathead hooked to a T-5 with a S-10 Rear axle on 35 wishbones,.... and loves it.
    I started to build this 33 Coupe as a beater,... then petered out. It has a 67' 9" Bronco rear in it .
    And this one had a 57' Rear axle under it.
  11. ss34coupe
    ss34coupe
    Anybody put the early Bronco axles in a 57-9 Ford rearend housing in order to get the 5 on 5 and a half bolt pattern? According to Fordcpe's chart above, the Bronco axles are three quarters of an inch longer than the 57-9 Ford axle - could that much be shaved off to make them fit? I have a pair of early Bronco axles and would put them in the 57 rear in my 34 coupe.
  12. Baron
    Baron
    3/8 of an inch off each axle should be no problem as long as the pinion gear offset is the same on both housings(if I remember correctly, the Bronco housing is centered with the pinion offset).
    Just found this thread.
    http://www.jalopyjournal.com/forum/showthread.php?t=583944
  13. ss34coupe
    ss34coupe
    Thanks for the info, Baron. I'll put the Bronco axles in a 57 housing and see how things fit to determine if this swap is feasible.
  14. Baron
    Baron
    Bronco axles 27 1/4" left ,29 11/16 rt ,from face of flange to end of axle.
  15. olscrounger
    olscrounger
    thx for the rearend width chart--just found an 8" that is 57.25--will work well in next 40.
  16. Shaggy
    Shaggy
    from Sultan, WA
    Olds and banjo should be the ONLY choices!!!
