sbf in a 36 without recess?? is it possible?????i really d'ont want cutting my firewall any tips???? thanks for reply
I thought there was a longer thread recently, but this is all I found: http://www.jalopyjournal.com/forum/showthread.php?t=653915&highlight=36+ford+cutting+firewall
Use pan, short water pump and accessories, as in '91 or so Cougar/T-Bird. In addition, the frame's front crossmember needs to be lowered (going with MII type suspension, or something similar. An alternative would be to drop the buggy-spring crossmember drastically, which would necessitate a deeply dropped axle in order for the driver to see over the front fenders. ) Without doing the above, I believe that the firewall must be recessed.
I can tell you for certain that a 302 will NOT fit in a '40 without major surgery, becaue I used to have one. Deep recess in firewall, trans tunnel. Even more on a '36. Brian
I have a 37 I am placing a 351 in using the 95 mustang short water pump , must use the same timing cover. This is a reverse rotation with the serpentine but you can get a pump with correct rotation to run V belts . This combo will shorten a SBF to the same specs as a SBC .
I have a 302 in my '40 with the original uncut firewall and long water pump. Just moved the radiator forward maybe an inch or so (very easy). It's not a '36 though.....
