studebaker OD relay
Discussion in 'The Hokey Ass Message Board' started by KUBE, Aug 20, 2012.
  1. KUBE
    KUBE
    from USA
    I am having a fit here guys... '53 Stude overdrive relay. The repops are not wired internally like the original.
    There are four terminals on the authentic piece. As far as I can determine, one terminal is "hot" all the time. Anther "hot" when the ignition is on. One more "hot" when the key is tuned and yet the last one hot when the governor reaches a certain speed.
    the question: Does anyone know for certain how these are wired and / or work?
    thanks much!
  2. zibo
    zibo
    from dago ca
    Ditch all that and just put in a relay and a toggle switch!
    TP
  3. Mike VV
    Mike VV
    from SoCal
  4. aircap
    aircap
    If all else fails ask over on the forum of the Studebaker Drivers Club.
  5. KUBE
    KUBE
    from USA
  6. KUBE
    KUBE
    from USA
    Tried that. No help whatsoever.
  7. Mike51Merc
    Mike51Merc
    Studes used basically the same Borg Warner OD as Fords/Linc/Mercs/Chevys did. Do a search here (and on the 'net) and you'll certainly find wiring diagrams.
    The relay terminals should be as follows:
    1. Power (which comes from the ignition coil, or at least from a source having the key turned on)
    2. Solenoid (power out to the solenoid when the governor triggers the relay)
    3. Governor (acts as a trigger for the relay).
    I don't know why you'd have (or need) a fourth terminal, unless Studebaker had the relay act as part of the kickdown mechanism. Fords had the solenoid wire pass through the kickdown switch on its way to the solenoid.
    Have a look here for a cool replacement:
    http://www.studebakerparts.com/studebakerparts/store/s/html/pages/relay.html
