Can You Weld In Holes On a Steering U-Joint?
Discussion in 'The Hokey Ass Message Board' started by Tattedkat, Jul 7, 2012.
  1. Trusted a Helper Friend of Mine To BARELY Drill Out The Misaligned Holes on My Smaller Steering U Joint. He Made a MESS! Now Its Either By a New One for Like $50! Or Weld The Holes Up, Smooth out, And Redrill THE CORRECT WAY so that the Pin Will Fit. Is It Possible to Weld on The Smaller Steering UJ's, Or Am I just Gonna Have To Fork The Cash over and Buy a New one? Thanks.
    P.S. Its a 3/4" DD to a 3/4" Round Smooth, No Splines.
      99.9 KB
  2. F&J
    F&J
    If it is steel, not iron, I'd weld it for sure. These days with all the crappy parts, it might be cast iron?
    Mig welding will leave a hardened spot, but a new sharp chainsaw file works nice to dress out the hole, if you just weld part of it up.
    Wet a rag and wind it through the joint X to keep the heat away from the joint cups.
  3. If its a good quality joint it will be forged or machined from billet so tap a peice of brass the same size as the steering shaft into where the steering shaft fits to avoid having to try and file the inside of the hole , then Just quietly weld it up with the mig, a little at a time to keep the heat down and avoid shagging the u-joint, pull out the brass plug,clean up and redrill.
  4. kscarguy
    kscarguy
    If it is on the DD side of the joint, you might consider inserting the DD shaft into the joint and making plug welds. I've welded steering joints to the shafts on several cars with thousands of miles and no issues. You want good weld penatration, but also want to avoid overheating the bearings. I fully agree with wrapping it with a wet rag. Let it cool slowly.
  5. kscarguy
    kscarguy
    My advice...don't let your friend work on your brakes. :)
  6. Phil1934
    Phil1934
    Why not drill a new hole 90 degrees from that?
  7. RodStRace
    RodStRace
    Go over to your trusted friend. Remove 50 bucks from him.
    This way there are 2 lessons learned:
    1. You don't trust him with your life
    2. He doesn't eff up parts
  8. I Could, But Wont It Look Shitty to The Eye with That big Ugly Hole?
  9. They look like weld on steering u-joints, so weld them on and forget about the bolts.
  10. willie57
    willie57
    from wisconsin
    spend the money buy a new one. what is your life worth.
  11. cjo13
    cjo13
    from SD
    By the looks of it I would use the Wet Rag and weld it also.. Just make sure you have proper heat and penetration.
    CJO13
  12. After Some Research, Its A "Sweet" Brand Weld On 3/4" Smooth X 3/4" Smooth U-Joint. Although The Rod is a DD Shaped Rod, I Dont Think Ill Have a Problem After I Solidly Weld Both Pieces Together with a Flux Arc Stainless. Ill Keep It Cool at all times.
      52.9 KB
  13. Don's Hot Rods
    Don's Hot Rods
    from florida
    Put your ground clamp on the side you are welding so current doesn't have to pass through the needle bearings.
    Don
  14. Hellbentrodder
    Hellbentrodder
    from Cotati
    Why are you going to use stainless? Unless you have 309 ss, there is a good chance it will crack.
  15. Don's Hot Rods
    Don's Hot Rods
    from florida
    Even though you are welding it I would still drill a hole all the way through and put an appropriate sized roll pin in it just for giggles.
    Don
  16. What About Manganese Hellbent?
  17. If you are going to weld it, remove the u-joint. Keep the joint end as cool as possible. You won't have any problems.
  18. Put the u-joint in a bucket/cup of water and weld it, much easier than taking it apart. A friend tig-welded this Flaming River u-joint for me just the other day.
  19. BRENT
    BRENT
    Like Phil1934 said!
    I would drill it 90 degrees from your current location that is misaligned. I would then weld up the holes. Easy fix!
    Brent
  20. oj
    oj
    Get a universal joint made for the double d shaft - they are not made to go together anyway esp if the holes are screwed.
    The double d will come loose as there isn't anything for it to seat into and bite against. You could weld the universal to the shaft - as another has shown - only one side needs to be able to be disassembled.
  21. Roger Walling
    Roger Walling
    For $50 its not worth the effort to weld it up.
    Let alone the fact that you will drive out all the grease from the joint, and wonder if i will be safe and not sloppy.
  22. dudley32
    dudley32
    X2...be safe not sorry....
  23. Hellbentrodder
    Hellbentrodder
    from Cotati
    I would just use ER70S (standard mild steel). I also agree with OJ, if you are using double D shaft you should use a joint made for it. At least two things need to be done right......steering and brakes!
