Guys im trying to figure out what carb this. 4224 is on each metering block. All carbs i see only has one fuel inlet and one metering block . As you can see in my picture it has 2 metering blocks. Thank you for any help <br>
Why is it when I look that up I only see one metering block on the front of the carb? Thank you for the help
I wonder if I would need a special rebuild kit because of the extra metering block. Sorry for the stupid questions but just want to be sure. As always thank you for the help.
You can buy the bowl and block gaskets separate. You may have to also buy a secondary power valve. If you need a whole kit, buy it and then buy the addition pieces individually. Just noticed they are sitting on a s/c, may not have power valves.
