Powered By Ford Thread
Discussion in 'The Hokey Ass Message Board' started by FordMaverickFanatic, Mar 5, 2010.
  1. uc4me
    uc4me
    429/C6 in my 55 f100
      105.1 KB
  2. 46poncho
    46poncho
    from Indiana
    Ok so I have a question? I have a 1946 chrysler windsor and I have a 351 windsor. My Idea is to have a windsor powered by windsor. the original chrysler motor is junk and the 351 is just sitting in the shop. My question is will I have to change the rear end. I am going to run a 3 speed od with it. What speed will it go with the stock 46 rear??? I am just building a crusier not a race car but would like to drive down th hiway at good speed
  3. mikemo
    mikemo
    I have some Ford powered Fords; '62 Bird w/390, '50 Club Coupe w/Flatty, '56 Bird w/ 312 Y-block & toploader, '36 pu w/5.0 (under construction).
      512.2 KB
      537.2 KB
      540 KB
      495 KB
  4. 65COMET
    65COMET
    46poncho;I would think that if you drive it sanely and smoothly you should be OK.I think the three speed will break before the rearend!I have a couple of friends running three speed/ODs and stock rearends in 50s Fords with 289 and 302 engines that have not had any issues! ROY.
  5. jimmy959
    jimmy959
    Here's a pic of my 429 (backed up by a C6) that's in my '58 Ranch Wagon.
      392.8 KB
  6. wisdonm
    wisdonm
    Here's my Italia.
    Some call them Italian Cobras. They had Ford power-trains. Some were even assembled by Holman Moody under the name Omega, but they took too long. I checked with Ford to find out what the factory option number meant. They said it was everything from the radiator to the rear end. They had the best small block for the year, mostly top loaders, and a 8 or 9 inch rear. They weighed less than 2,600lbs.
  7. 40FordGuy
    40FordGuy
    LOVE the '54 Ranch Wagon!!!!!!!! "54 was one of the best looking offerings from Ford, during the 50's. GREAT job on that .......
    4TTRUK
  8. SOHC427
    SOHC427
    Now you talking! I like the way you think!!
    Eric
  9. Tacson
    Tacson
    Sweet what is that radiator out of??
  10. Back on 3-5-2010 I posted a couple of photos of the unfinished engine & car,,here are a couple of current photos. HRP
  11. JLGrist
    JLGrist
    My '51 F1 with 302/AOD
  12. enfieldjoe
    enfieldjoe
    from Eustis, FL
    My Custom 51 Merc chassis with a SBF 347ci stroker and an AOD trans. Also using a 9" rear and four link suspension.
  13. 64falconsix
    64falconsix
    from Daphne Al.
    The Tri-power 200 inline in my 64 falcon.
  14. Harvey29
    Harvey29
    from kansas
    Sbf c4 9 in all Ford on a Ford in a ford
    Sent from my DROID device using the TJJ mobile app
  15. teddyp
    teddyp
  16. Super Streak
    Super Streak
    from Florida
    These are some pictures of my model A coupe. It was built by a fellow hamber ( Razor ). It's powered by a 302 Ford with a C4 and an 8" maverick rear. I've made a couple of minor changes since I bought it and use it as my daily driver.
  17. teddyp
    teddyp
  18. teddyp
    teddyp
    this is cool a plym. with a ford in it not the boreing must be a ford in a ford or a chevy in a chevy use a body that you like and a motor that you like THATS REAL OLD SCHOOL HOT RODDING
  19. nailhead terry
    nailhead terry
    Heres mine I was a chevy guy now converted 347 and tko 500 fun fun
      148.4 KB
  20. kracker36
    kracker36
    289 in my Hot Rod. I got the core from an old Ford truck that I bought for 200.oo. It had the M/T valve covers, Edelbrock intake, and MSD Ignition. I built it for my IH hot rod. If you notice in the pic, a friend of mine( BOutlaw here) put his ice cream on the intake to help thaw it out while we were at cruising the coast :D
  21. "86 302-c4 trans
  22. kyvetteman
    kyvetteman
    Do Mercs count? ;)
    [​IMG][​IMG][​IMG]
  23. Dave Mc
    Dave Mc
    29 has a Edelbrock carb 302 w/ C 4
    33 has a Fuel injected 5.0 w/ AOD
