shift pattern on a torqueflight 727 trans?
Discussion in 'The Hokey Ass Message Board' started by old bone, May 3, 2012.
  1. old bone
    old bone
    from maine
    so im using a torqueflight auto 727 trans on my project..and it is time to make some shift linkage..problem is i forgot the shift pattern..i think i rember park being in the most forward position twords the engine..am i right?..
  2. old bone
    old bone
    from maine
    honestly..i think your wrong
  3. old bone
    old bone
    from maine
    talking about the lever..twords the engine is park...right?
  4. should be park, reverse, neutral, drive, 2, 1
  5. Ebbsspeed
    Ebbsspeed
    In both of the posts above the positions are called out in the correct order, you just need to figure out which lever position locks up the tailshaft, and then you can go from there. R is next to P, N is next to R, and so forth.......
  6. swifty
    swifty
    No, with the lever fully forward towards the engine that is first then every step back is a shifter position, i.e. 2, D, N, R, P .
    Stick a slip yoke in the output and check that with the lever fully back the trans is locked. All other positions it is free.
  7. old bone
    old bone
    from maine
    thats what i thought....park is most forward twards engine...one is twords back
  8. old bone
    old bone
    from maine
    tis is no test...but damn i think your wrong too
  9. old bone
    old bone
    from maine
    no 727 torqueflight guys here?
  10. dalesnyder
    dalesnyder
    1st is toward engine.
  11. old bone
    old bone
    from maine
    pretty ...sure park is twords engine.....are you sure?...
  12. old bone
    old bone
    from maine
    duhhhh...trying to figure if is P is most close to forward ( as i think) or if P is most close to back...not barain sugery...
  13. old bone
    old bone
    from maine
    how do you know this?
  14. old bone
    old bone
    from maine
    now im sure your mother dropped you on your weak skull
  15. old bone
    old bone
    from maine
    this aussi might be right....what the hell americans?
  16. old bone
    old bone
    from maine
    im dam sure he is not
  17. If you have a floor shifter and you push it all the way forward it would be in park.
  18. push the lever forward and check to see if the tailshaft locks.if so thats park.if not go the other direction.
  19. old bone
    old bone
    from maine
    thats what i rember..takes me a long time to build hot rods..need to know before i set up the linkage on the tunnel
  20. old bone
    old bone
    from maine
    building a car from ground up.. not running...squared up front end to rear...guess your not understanding
  21. old bone
    old bone
    from maine
    yes..floor shifter....so...if you push your lever forward..it goes...nevermind...you dont know...simple as that...why do you even anwser something.....leave it to the old guys im asking
  22. old bone
    old bone
    from maine
    wow..what a bunch of short bus anwsers i got....so lever twords engine is park?...
  23. old bone
    old bone
    from maine
    what lever?...have not built it yet..talking abot trans 727 torqueflight
  24. old bone
    old bone
    from maine
    any way..torqueflight 727 a is a grat trans..just cant believe no cool old dudes know the shift pattern....i will figure it out on my own
  25. old bone
    old bone
    from maine
    thanks for the help...your knowledge is unforgetabile...
  26. dalesnyder
    dalesnyder
    I have one in my car. The lever on the trans is pushed toward the engine when in lo gear.
  27. dalesnyder
    dalesnyder
    Yeah , I have heard that before.. But right now my 727 is in park, and the trans lever is toward the back of the trans..
    How is your skull?
  28. dalesnyder
    dalesnyder
  29. Pretty easy to tell, you will feel the park pall engage and also their is quite a bit of throw between park and reverse.
  30. My fury has a 727 trans and I am just stating how it works in my car. Of course it is a column shift so I guess maybe I was wrong with a floor shifter pushed all the way forward being in park, but I have never seen any transmission that was different than that. But mother Mopar did put left handed threaded wheel studs on the left side of their cars so who knows. I think its all a big conspiracy by GM and Ford to keep the man down. I think I need a cookie...
