carb swap edelbrock to holley question
Discussion in 'The Hokey Ass Message Board' started by vintage_car, Apr 24, 2012.
  1. vintage_car
    vintage_car
    I have an old edelbrock 650 manual choke sitting on a edlebrock performer dual plane manifold. the carb is leaking badly from various places. I'd like to swap to a holley. Is there a specific 650 from holley that I need to work with my intake? manual choke is still fine by me.
  2. DeucePhaeton
    DeucePhaeton
    IMO, You'll be sorry.
    I swapped from a trouble-some Holley to an Edelbrock 19+ years ago and never looked back. never touched it again.
  3. Well do you need a vacuum secondary or a double pumper ? If you could get a vacuum secondary style carb that would be good for you.
  4. vintage_car
    vintage_car
    it seems to be flooding out the truck. with the fuel pump running and psi at 5, fuel drips pretty steady out of the 2 marked areas in the photo. even after the truck is off it will slowly drip.
  5. ididntdoit1960
    ididntdoit1960
    from Western MA
    What motor? What car? What gear? What trans? What cam? What do you do with the car? All that said........if the edelbrock made you happy - i'd go with the old reliable list# 1850 vac secondary 600 cfm
  6. ididntdoit1960
    ididntdoit1960
    from Western MA
    How much tension is/has been on your return spring?
  7. vintage_car
    vintage_car
    good tension is on the return spring. I have a dual spring setup. the gas pedal does take a bit to push.
    It is a rat rod truck, 350-v8, crane energizer cam, 882 heads, headers, th-350, drive it when it isn't raining on the highway about 50 miles to and from work- highway speeds...and a few fun burnouts.
  8. el caballo loco
    el caballo loco
    from colorado
    ok, i'll play. my edelbrock to holley question is... Why? And, the return spring is the thingie that closes your throttle when you lift off the gas. Looks like it's bleedin past the throttle shaft to me. You can have that sorta thing repaired. I'd stick with an edelbrock but that's just me. Had experience with both brands i just prefer an edelbrock. Opinions may vary.. :)
    checkout this page, its eddys tuning page. straight from the horses mouth so to speak, tell ya everthing ya ever wanna know bout em. :)
    http://www.edelbrock.com/automotive_new/mc/carbs_acc/pdf/carb_owners_manual.pdf
  9. 32ratsass
    32ratsass
    The Edelbrock could probably benefit from a carb kit, and a float adjustment. Your picture indicates a probable float level problem or a needle/seat leakthrough problem. No matter what, from a reliability standpoint, and freedom from external leaks, you're going to be better off with the Edelbock.
  10. Deuces
    Deuces
    I'd go with the 1850 carb also!!!!!!.. :D
  11. vintage_car
    vintage_car
    alright, I see that I have started a holley vs. edelbrock carb thread...
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    As a few others have said, It's fuel pressure related (your test gauge may be bad) or a needle and seat issue. Double check those two things, the Carb is not junk.
  13. Deuces
    Deuces
    Yep!...:D I'm a BiG fan of Holley carbs...;)
  14. zman
    zman
    from Garner, NC
    hmmm...
    then you said this...
    I'm guessing you're confused as to where you are...
  15. Standard gas&oil
    Standard gas&oil
    from USA #1
    X2 - $35.00 for a new rebuild kit and that thing will run like a champ. You already own the carb why pay $250.00 + for a new Holley?
  16. Larry T
    Larry T
    A 1850 Holley (600 CFM) is a square bore carb and will bolt on where an Edelbrock was. You'll have to move the throttle linkage/cable but that's about all. Maybe mess with transmission cable if it has one too.
    Aren't the Edelbrocks rated at 625 CFM? I know they used to be.
  17. vintage_car
    vintage_car
    not a forum that likes rats?
  18. God I love this manual! :D I had an auto tech instructor years ago that had the entire class drawing carb circuits like this from memory for our Fuel Systems tests. Once you study this stuff as individual circuits you begin to realize that carburetors aren't nearly as complicated as they seem. OK, maybe just a little complicated. :rolleyes:
    But here's the real bonus. These circuits aren't just in Edelbrock and Carter carbs. You'll find the same stuff used in Rochesters, Holleys, Motorcrafts and on and on! :eek:
  19. trilobyte
    trilobyte
    Only thing that I can think of is if you switch to a Holley, you might have to spend some time getting it all tuned to perfection, where if you got another Edelbrock, you could use the old one as reference.
  20. dickster27
    dickster27
    from Texas
    I notice you have a dial regulator. Turn it down a bit and see if that don't reduce or stop the seepage.
  21. JeffB2
    JeffB2
    from Phoenix,AZ
    A lot of those dial type regulators are junk,the old FILT-O-REG's were good but the offshore copies are hit and miss like Mr.Gasket and Spectre both have a lot of negative feedback on Amazon ratings.Like mentioned above check the fuel pressure with a gauge to see if the regulator is OK.The area you show leakage from is common with Quadrajets and Holley shaft bushings but very rare on AFB's and Edelbrocks.This fuel line I like as it has a port for a gauge http://www.summitracing.com/parts/SPE-29883/ then you can screw in a gauge http://www.summitracing.com/parts/SUM-G3122/ I have used several in the past.
  22. patrick english
    patrick english
    from La puente
    just rebuild that thing....also,i thought you got banned for saying the r word?
  23. Moose223
    Moose223
    Fuel pressure, simple rebuild on carb. And stick with the Edelbrock
  24. Don's Hot Rods
    Don's Hot Rods
    from florida
    Bingo. :D
    One more vote for Edelbrocks. Holleys may pump out a little more perfromance, but on the street and Edelbrock can't be beat. Super troublefree.
    Don
  25. el caballo loco
    el caballo loco
    from colorado
    +2 on the junk dial regulators. When i swapped my 2 bbl for a 1405, i bought the horror stories and added one. It stayed about 5 minutes. Removed it and my pressure gauge says 6 p.s.i. and everythings workin perfect.
