Anyone have a basic wiring diagram they want to share? I am running a late 60's gm column, with a 350/700r4 combo, and only need basics, lights, turns, charging system. Also have an inline brake switch. Last, what do I want to do for a safety switch so it wont start in gear, running a aftermarket floor shifter w/o a setup for a safety switch. Is there something I can mount to the tranny? Thanks....Scott
Scott, You can download wiring instruction in a .pdf file from ezwire. I have a 51 Merc that I put a 350 crate engine and 700R4, I am using a early 80's steering column. John
so, not buying a kit with correct parts and instructions? also, get a copy of "How To Wire Your Street Rod" from Speedway and others. covers wide range of info.
