Looking to upgrade MC to dual bowl after performing front disc brake conversion. All the MCs look to be 2/4 bolt. The truck is a 3 bolt. I have seen various things on adapters and what not. I am planning on leaving the truck with mechanical brakes. Any suggestions or advice from someone that has been through it would be appreciated.
You will want a master cyl for disc/drum with correct propotioning valve and posibly residual valve. Contact these guys and their tech department can help you select what is correct for your application. THE RIGHT BRAKES ARE IMPORTANT' http://www.performanceonline.com/Master-Cylinders-Parts/
