Help please, is this a 32 ford axle?
Discussion in 'The Hokey Ass Message Board' started by joe little, Jan 12, 2012.
  1. joe little
    joe little
    from UK
  2. carcrazyjohn
    carcrazyjohn
    from trevose pa
    32 to 36 are the same axle .I dont think those drums are 32 though.
  3. deuce354
    deuce354
    32 to 36 are not the same axle. It looks like a 32 heavy axle, but the drums are 36 to 39 wide five
  4. F-6Garagerat
    F-6Garagerat
    In the second pic, it looks like it took a pretty hard hit.
  5. Royalshifter
    Royalshifter
    Moderator
  6. johnny bondo
    johnny bondo
    from illinois
    in one picture the bosses look wide apart, and in another they look close, very odd.
  7. gasheat
    gasheat
    from Dallas
    Get the seller to send you a better picture of the FRONT of the axle at the spring perch hole. If it is shaped like the end of an I-beam, its a 32. Does not look like it is from the pictures furnished. Drums are wide 5. 32 heavy and 36 axles will never be the same.
  8. Rem
    Rem
    The spindles look Model A to me, with bolt-on steering arms.
    And the way the perch bosses stand pround of the beam looks Model A too. Ask him what the thickness is at the perch boss holes: 2-1/4" would make it Model A (or '37-'41 as well), and 2" would make it '32-'36. It's definitely not a '32 heavy, and with the short ends, my bet would be '37-'41.
    Don't know about the drums - they sort of look like wide-5 bolt pattern, but not wide enough? I wonder if it's an English Ford axle, E83W or something?
  9. tommy
    tommy
    No it is not a 32 heavy axle. In the second picture you can clearly see the boss around the spring perch hole. Look at the above 32 axle pic. to see that this area is recessed on the desired 32 axle.
  10. model.A.keith
    model.A.keith
    Dosent look to straight either...:confused:
  11. Blackie
    Blackie
    Listen to this man. Not a heavy '32.
    Sent from a pay phone
  12. Mark T
    Mark T
    Looks like the '37-'41 axle pictured above
  13. MissPrint
    MissPrint
    Although I cannot offer anything regarding proper I.D. of the axle, I would also say, be a bit "wary." The seller has no earlier sales, no feedback, no additional ratings/rankings or information, and has only been a seller since December.
    I know we all have to start somewhere. . .but I'd say, "Caveat emptor." FWIW. :cool:
  14. 117harv
    117harv
    X2..and the drums look to be 37-39 with the shorter snout, with the drum mounted on the wrong side of the hub.
  15. joe little
    joe little
    from UK
    Thanks for all the info guys. Think ill steer clear of this one.
    Cheers Joe
  16. joe little
    joe little
    from UK
    Cheers Joe
