39/40 Ford Pickup - to chop or not to chop?
Discussion in 'The Hokey Ass Message Board' started by Outback, Nov 22, 2011.
  1. Outback
    Outback
    from NE Vic
    I've started piecing a 39/40 pickup together, it'll be mostly stock, running an 8ba early g/box fully fendered, and initially at least an undropped axel albiet lowered in the springs, stock chassis, with 16" steelies. sans bumpers, stock length bed (probably)
    I'd like to give it a bit of a hair cut however I'm struggling to find any pic's of these pickups with a small chop and not super low look any good.... following??
    Anyone got any pics??
    Cheers
    Outback
  2. chrisntx
    chrisntx
    from Texas .
    39 and 40 are two Very different trucks and both are Very small inside. I have been driving a 39 everyday for 17 years and it will be unacceptably tiny if its chopped. By that I mean if you DRIVE it, if you only drive it on rare occasion you may not care
  3. Ed Wrath
    Ed Wrath
    Pease don't do it!...............The proportions will be ruined........IMHO
  4. Blackie
    Blackie
    Look up Dan Collins' '38 or '39. Old Gold Garage. Proportions look pretty good to me. Also, Gambino Customs is building a '38/9 with a '36 car front that is coming together nicely. There are some nice pics of the chop process. If you have a '40/41 I can't think of any good examples but am sure they are out there.
    Sent from my POS phone.
  5. mow too much
    mow too much
    You ask to chop or not. I say not, as Ed Wrath stated above, it screws up the poportions.......just because you can doesn't mean you should.
  6. Saxon
    Saxon
    from MN
    39 to 40. definitely a difference.
    Some samples.
    38, always liked this one.
    1940, ooops picture is huge. Sorry
  7. oldcarfart
    oldcarfart
    2X, but if you do keep it at a 2" cut.
  8. speedyg948
    speedyg948
    have seen examples of both, love the cabs at stock height.... but to each his own and i dont think 2" is too much
  9. pops29
    pops29
    from turlock ca
    Here is some older pics of mine as Alex Gambino is beginning the chop . If the chop is done right ! you will not lose the proportions. Alex is the man! ... search this thread and see how it is done, Technical LETS CHOP A 39 FORD TRUCK CAB 100's of pics and vidios
    before
    after
    EVL401 likes this.
  10. Don Martin
    Don Martin
    from West Tenn
    I drive a 39. Full fender,stock bed. Not chopped but cab is mounted on the frame without the wood mounts. This make the truck appear lower without giving up interior space. Removed 2 front springs to lower it,looks good,rides good.
  11. treb11
    treb11
    I swear up and down that R&C had a chop article where only the rear of the cab was chopped and the windshield stayed the same height. it takes the "hump" out of the cab and was a great improvement.. I thought I bought the magazine but can't find it for love or money. May not have been R&C. Can anybody verify this?
  12. Saxons examples above only confirm the feelings I've always had, chopped cabs on these throw off the proportions. No chop gets my vote. But in the end, the decision is yours.
  13. mlagusis
    mlagusis
    if it is a 39 chop it...if it is a 40 do not chop it
  14. Saxon
    Saxon
    from MN
    Yes they are some extreme examples, maybe those are a little more then asked for.
    Although that green 38 looks a little funky, I like it. Could be the overall finish of the truck.
    Just a trim looks good and this is coming from a guy that has a 38 that will not get the blade.
  15. ems customer service
  16. metalix_421
    metalix_421
    I think 2 to 3 inches is about all I would do on it. so yes to chop
  17. F&J
    F&J
    Winner ^
    If I did one, i'd remove some of that ramped sheetmetal under the windshields, and maybe up top of the w/s too. That's why they look like crap as far as proportions, if it has a moderate to heavier chop.
  18. MrForty
    MrForty
    from Tustin, CA
    I like the proportions without a chop.
    Drop it not chop it.
  19. reefer
    reefer
    I prefer the 40 pickup chopped..in my eyes it improves the look of the cab...it looks less gawky.
    EVL401 likes this.
  20. Pinstriper40
    Pinstriper40
    If done right either cab looks right. A chop only improves proportions on the early fords- except of course with the '37-'40 coupes!
  21. chappys4life
    chappys4life
    from Austin, TX
    39 chop, 40 never chop!
  22. AnimalAin
    AnimalAin
    My '41 pickup is already small enough inside. With the stock top, I look through the top third of the windshield. At the very least, make sure you have a seating plan that will work before you start cutting metal. It would be a shame to have a bitch'n hot rod pickup that you don't fit into, or can't see out of.
  23. Deu55
    Deu55
    Hey Outback have 2 pix hope it helps, looks good without IMO ..Rod
    Sent from my iPhone using TJJ
    EVL401 likes this.
  24. Deu55
    Deu55
    Found one more..hey Dick and myself have pickup projects also...
  25. rustyford40
    rustyford40
    from Mass Bay
    I chose to channel my 40, and I like how it came out
  26. 1 KooL "MoFo"
    1 KooL "MoFo"
    Chop it !
    Would look grate I'm working on a 37 ford P.U. had a 4" chop on it
  27. We chopped my 40 PU 2" and left the back window stock height, also built a new seat riser that sits 2" lower. Take a look at Gambino's as mentioned above, it's the best I've seen.
    GOOD LUCK!
  28. I vote for stock height. Although the '38-'39 cab is a totally different animal from the '40-'47 cab, the amount of interior space is about the same. I'm a big guy--6'5" and 265 #--so I wouldn't want my '38 to have any less head room or leg room.
  29. desotot
    desotot
  30. Dan in Pasadena
    Dan in Pasadena
